Old 05-16-2012, 01:05 PM   #91
Drakconian's Avatar
Herk,
Do you have any pics at night to post?
2012 Primetime Lacrosse 318BHS
2003 GMC 2500 HD Diesel
Reese 1200lbs Dual Cam SD Hitch
Drakconian is offline   Reply With Quote
Old 05-16-2012, 01:08 PM   #92
TURBS's Avatar
I did just notice that the set i ordered which is the same as the op's doesnt turn white . hmmmm no biggy i guess !
Old 05-16-2012, 01:39 PM   #93
Herk7769's Avatar
Originally Posted by Drakconian View Post
Herk,
I lost them when the computer ate my camera chip. It was going to rain so I took the controller down. I am camping this weekend and will shoot some night shots friday night.
HAM CALLSIGN - KC3FFW
Old 05-16-2012, 01:44 PM   #94
Herk7769's Avatar
I noticed this for those who want to plug it in.
12V 3A AC/DC Adapter Power Supply for LED Strip US plug | eBay
Old 05-16-2012, 01:50 PM   #95
Drakconian's Avatar
Thanks Herk
Old 05-16-2012, 01:57 PM   #96
Herk7769's Avatar
There are two buttons on the remote in the upper left hand corner of a little "sun" with an arc on top (on one button) and below the sun (on the other one). Those buttons will dim or brighten the LEDs.
Old 05-16-2012, 04:10 PM   #97
wagon52's Avatar
Someone please help! So I ran a red and black wire up the awning arms with the wire for the awning motor. Cut the plug off the 110v power supply and connected them to the wires I ran down the arms. Ran the wire in where the awning motor wire goes in to my front storage. Now I've tried to tap into the front storage light. I assume one is power and one is ground? Either way, I can't get the lights to work. Anyone have any ideas what I'm doing wrong? Like I said I'm not an electrical genius.....
This is where the wires are
ID:	13972   Click image for larger version
ID:	13973   Click image for larger version
2012 Rockwood Signature Ultra Lite 8312SS
2008 Rockwood Roo 21SS (History)
1981 Starcraft Galaxy 2108 (its gone)
1999 Dodge Durango (Retired TT)
2006 Dodge Ram 3500 Quad Cab 4x4
wagon52 is offline   Reply With Quote
Old 05-16-2012, 05:57 PM   #98
wagon52's Avatar
Disregard, I figured it out. And it's pretty swanky if I say so myself!
Old 05-16-2012, 06:00 PM   #99
Herk7769's Avatar
Attachment 13971
I see the transformer on the hood of your truck. When you cut the plug off were you able to figure out which wire was 12 volt hot and which one was 12 volt ground?
DC Polarity is critical as hooking it up backwards can destroy the controller if there is no internal protection for that eventuality.
I also looked at the wires on your basement light. One red and one white goes up the arm correct? The red wire (also black to the light itself) is the hot one and should be connected to the red wire in the plug you cut off to maintain correct polarity.
Also the 4 pin socket MUST be plugged in with the two arrows on the connector lined up. There is a warning in the paper that came with the unit that plugging the LED strip in reversed can short circuit the strip.
Do you have a meter? Can you verify there is 12 volts inside the plug when measured from the inside to the outside of the barrel.
Also check how you plugged in the socket that the arrows are lined up (hard to see on the black one but it is there).
Good Luck
Old 05-16-2012, 06:01 PM   #100
Herk7769's Avatar
Just missed!
Pictures please!
awning, led pad
