Old 04-13-2013, 06:04 PM   #1021
Phat Phrog
RVChick's Avatar
Oh no what a mess!!
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 04-13-2013, 06:10 PM   #1022
LKicklight's Avatar
Mess
I must agree..they worked so well in the garage prior to going on..nothing got damaged and everything looks great in regards to the install..
Just sent the seller a note explaining what has happened, hopefully they can get me another set sent right away...thanks
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 04-13-2013, 06:14 PM   #1023
Phat Phrog
RVChick's Avatar
Oh good....
Kenny n Karen
Old 04-13-2013, 06:22 PM   #1024
Owner/Operator
RodeoGeorge's Avatar
Are you using an IR (Infra Red) Controller, or an RF Controller?
Sunlight can, under certain circumstances, interfere with the operation of an IR controlled device. You might try again after dark.
If you do decide to obtain a different controller, Post #1009 has a link to a relatively inexpensive RF Controller (#1 in the choices). And one of the links for this controller is for a US Supplier.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 04-13-2013, 06:23 PM   #1025
Turtle people's Avatar
When I first got my lights I tested them as well, power was not supplied with my order. I went to radio shack, and bought a multiple tip/ power supply DC cable. At first the did not work??? I then realized the power was set to 3 volts. Switched to 12 volt and the lights would trouble flash. Problem was a 12 volt supply was o.500mg amp, for se reason it worked on the 9 volt setting. I went and got a new 12 volt 1.5 MHz amps ( long story short) one with enough power and amps to work properly. WOW what a difference, if your having a similar issue it could be power supply from TT. Did you cut off the Dc plug in and wire it in?
Turtle people is offline   Reply With Quote
Old 04-13-2013, 06:32 PM   #1026
Stanleyg's Avatar
Awning Lights
Here are a few pics of how I mounted and ran the wires for my awning LED lights.
ID:	27833   Click image for larger version
ID:	27834   Click image for larger version
ID:	27835   Click image for larger version
ID:	27836   Click image for larger version
Stan, Wanda, Sheray, Alex, Nicky, and Macky(the Chorky).
2013 Prime Time Avenger 33BHS
Stanleyg is offline   Reply With Quote
Old 04-13-2013, 07:04 PM   #1027
LKicklight's Avatar
wow-rodeogeorge
Don't know how to really express this, but anyone not a part of FROG needs to get another camper...thanks to my new found FROG, George...the sun is setting and the lights are working...I would never given that the first thought in my pea brain...sure they will work even better when it gets really dark, but for now, they are fine..My wife is making posters for a light show here at our driveway..ordered another set of the Sunnybrook..can't leave her out...i WILL SEND PICTURES,,KEEP IN MINE, THE CRU STILL HAS HER COAT ON FOR WINTER...WANT COME OFF TILL THE POLLEN IS ALL GONE...WAS A 8000 TODAY..
THANKS FOR THE HELP
Old 04-13-2013, 07:12 PM   #1028
LKicklight's Avatar
#1009
how can I find that post..maybe a good idea...thanks
RodeoGeorge
Old 04-13-2013, 07:29 PM   #1029
Fivenikkels's Avatar
Had our lights on before we left last week for Tennessee ran through arm of awning underside covered with white duck tape so you can't see wires then into out side kitchen couldn't have been easier lots of compliments now need to figure out how to make them dance with the music that would be kool
ID:	27846   Click image for larger version
Fivenikkels is offline   Reply With Quote
Old 04-13-2013, 07:53 PM   #1030
TURBS's Avatar
Hard to believe this thread has been viewed 92,000+ times !!!!!!!!!!!
awning, led pad
