Old 04-14-2013, 10:13 AM   #1051
pwrboatfan's Avatar
Are those 12volt switches? Where did you buy those?
2006 Salem 392FKTB PT
Seasonal Camping at Pomme De Terre Lake in MO
pwrboatfan is offline   Reply With Quote
Old 04-14-2013, 10:57 AM   #1052
Herk7769's Avatar
Originally Posted by Stanleyg View Post
Here are a few pics of how I mounted and ran the wires for my awning LED lights.
Stanley,
Initially I mounted mine exactly where you mounted yours. They worked great until the first big rain, then my lights went "wonky." Discovered that "weather resistant" did not mean "waterproof."
I relocated the light driver computer inside after that.
Herk
ID:	27872   Click image for larger version
ID:	27873   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 04-14-2013, 12:50 PM   #1053
Tonk Mom's Avatar
I don't understand the above photos. Is this where things are now? I see the little white box is not connected to anything in the first two photos.
Jill
Jill and Ed and the kitties
1998 Coachmen Leprechaun 31Q
Tonk Mom is offline   Reply With Quote
Old 04-14-2013, 01:03 PM   #1054
Herk7769's Avatar
Not sure what you mean. The little white box is connected to 12 volt power and the connector for the LED strip is plugged into the LED strip in the two photos.
The bottom photo shows where I moved it so it would stay out of the rain.
Old 04-14-2013, 01:11 PM   #1055
spierce617's Avatar
Herk, How did you run the RGB cable down into the compartment? Did you use a 4 wire cable to do that?
1999 Chevrolet Suburban 5.7L V8
2005 Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 04-14-2013, 01:14 PM   #1056
Herk7769's Avatar
Yes, I used a 4 wire "Telco" cable. (4 conductor "bell wire" telephone wiring) to feed from the LED strip down to the motor wire hole; then inside the storage compartment to the control unit. I fed the sensor back out through the same hole.
ID:	27886   Click image for larger version
Old 04-14-2013, 01:20 PM   #1057
spierce617's Avatar
I have a manual awning and looking for ways to install it with minimal drilling of holes in the side. Looking to run the wiring down inside the refrigerator compartment and then tap the power there.
Name:	2005 Cherokee.jpg
Old 04-14-2013, 02:24 PM   #1058
Turtle people's Avatar
Try to house everything into the orange light off your door. It will have power, provide water cover for the controller and no holes. The only down side is it might not reach the entire length of the awning.
Turtle people is offline   Reply With Quote
Old 04-14-2013, 04:57 PM   #1059
crunchman12001's Avatar
pwrboatfan,
Yes, those are 12 Volt switches. I bought them on Ebay here: New camper Sigma 12V Single Gang Rocker on Off Switch | eBay
I was able to find switches that match the ceiling lights from the factory.
I made the labels on the computer and used some clear label stock to label them for us.
This seller on Ebay was a fast shipper and has great prices. She has several different types of 12 Volt switches.
crunchman
2015 F-250 FX4
Old 04-14-2013, 05:35 PM   #1060
pwrboatfan's Avatar
Originally Posted by crunchman12001 View Post
pwrboatfan,
crunchman
Thanks!
awning, led pad
