Old 06-21-2018, 07:48 PM   #1981
RandK-M's Avatar
Originally Posted by JayArras View Post
A Google search turns up nothing under that name. Got a link?
I think he means these:
https://ucampproducts.com/shop/rollu...essory-holder/
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
RandK-M is offline   Reply With Quote
Old 06-21-2018, 07:54 PM   #1982
Kasual Kamper
Originally Posted by RandK-M View Post
Thanks, Ray, but I can't see how you can leave the lights on if you use those.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 06-22-2018, 01:38 PM   #1983
Who Dares, Wins
doc73's Avatar
If that is what he was talking about, I have them. THEY roll up into the awning when it is rolled up, NOT the lights. They need to be strung each time you put the awning out.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 06-22-2018, 01:49 PM   #1984
Kasual Kamper
That's what I thought! Thanks for the clarification. I'm looking for lights that will stay in the track when the awning is rolled up.
Old 06-22-2018, 01:56 PM   #1985
Who Dares, Wins
doc73's Avatar
Some people have used the similar:
https://www.solidapollo.com/led-strip-profiles/
Its a track you put the lights on on the side of the camper, not the awning itself, but just under. I would do this for my next set of LED because they all do fail eventually, esp the cheapy ones, so I could pull the old out and swap out with new without needing to remove the glue / tape.
2015 Chevy HD D-Max
Old 06-23-2018, 10:26 PM   #1986
Stealth13's Avatar
Originally Posted by judge3 View Post
I would like to mount LED strip lights wired in to 12V. Plan on removing porch light since it is all but useless. Would like to use 16 ft. strip, but connection at porch light position seems to require cutting strip and adding connectors. Has anyone tried this?
Yup, I drilled through the porch light housing. Took out the bulb and broke the bulb. I then soldered my connection to the bulb leads and removed the element. Insulted, installed bulb and lens. The switch for the porch light turns the strip on and off and the remote changes the colour and the fade. Click image for larger version
ID:	176995Click image for larger version
Stealth13 is offline   Reply With Quote
Old 06-24-2018, 09:13 PM   #1987
I’m interested in installing LED’s under the awning of our Sunseeker 3010, I would like to hard wire the installation, I would like to know if anyone has done this, I would appreciate any tips on the install. TIA
Chas69 is offline   Reply With Quote
Old 06-25-2018, 01:34 PM   #1988
Do a search in this website... tons of inf.
grayfox is offline   Reply With Quote
Old 06-25-2018, 04:01 PM   #1989
RubenZ's Avatar
I personally would put the light on the actual side of the RV and wire it to the outdoor light . Go with something like this and drill and seal a hole right by the Patio Light and tap it in there. This way it works with the outside light switch.
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 06-25-2018, 04:12 PM   #1990
Flybob's Avatar
The strip will have a connector on one end. Where do you plan to mount the controller? Cutting is easy just cut where marked. I suggest you purchase some 3M automotive trim tape add it between the sticky side of the led strip and the wall. The strip adhesive does not hold up well in the elements.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-25-2018, 05:03 PM   #1991
dcheatwood's Avatar
When I mounted and installed my multicolored LEDs, I got power by running a wire down the awning channel mounted forward on the fiver where the awning motor is wired. Fed the wire thru same hole in the channel where awning power wire entered the lp storage bin. From there I drilled a small hole from lp bin to basement where basement light was mounted and tapped into power there. I mounted the controller for the remote at the top of the awning channel where the led strip started. For ground wire, I backed out an awning mounting screw and placed ground wire behind it and tignened.
Works well except when awning is closed the controller is blocked from reading the remote because the awning blocks it.
2018 Forester 3011 DS
awning, led pad
