Old 04-18-2013, 10:56 PM   #1091
Owner/Operator
RodeoGeorge's Avatar
Sorry, grabbed the wrong thread.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 04-19-2013, 09:18 AM   #1092
Barney1's Avatar
Originally Posted by Barney1 View Post
OK I broke down and ordered this one.
5M SMD RGB 5050 Waterproof Strip light 300 LED + 44 Key IR Remote + 12V 5A power | eBay
RGB 5050 Waterproof Strip light 300 LED & 44 Key IR Remote 12V5Apower supply
I will most likely just plug it in with an extension cord.
UPDATE:
I received my LED light strip yesterday (Apr 18th) that is 8 days from Hong Kong. I can really complain about that.
PROBLEM:
On the shake down test the light strip didn't work properly.
The blue LEDs on the strip are always ON when there is power to the unit.
^ Oh look the sad emoticons are blue, how apropos!
STEPS TO RESOLVE:
I contacted the eBay seller. After some back and forth troubleshooting the eBay seller sent me the reset procedure for the 44 Key LED strip controller (part# 073-004). NOTE: You won't find the part# on the controller.
I will post the rest procedure below.
For me the reset did not work.
Form this the dealer is concluding that the fault must be with the strip. The have offered to send me a new LED strip at no charge. I said sure.
I am now in wait mode again
Here is the reset procedure
HERK PUT THIS IN YOUR LIBRARY.
Barney
2012 Rockwood Roo 233s
2011 Ram 1500 Big Horn V8 Hemi
Previous Trailer -> 1996 Jayco 1207
Barney1 is offline   Reply With Quote
Old 04-19-2013, 09:21 AM   #1093
TURBS's Avatar
Site library as well.
Old 04-19-2013, 09:26 AM   #1094
LKicklight's Avatar
Led light operation
Found out the hard way, when checking the install, be sure it is DARK outside, the controller does not like SUNLIGHt and will not work...almost ripped the whole install out before some really smart PHrog got me back on the right track..Line of Sight on the Controller...got to be able to see the Transformer Sensor...
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 04-19-2013, 09:33 AM   #1095
prof_fate's Avatar
Originally Posted by Tonk Mom View Post
Well, I need one. Any suggestions? We went to a car dealer yesterday and they kept telling me the cars available can't be towed four down.
The issue is that moving parts need lubricated and almost all automatic transmissions have a pump drive by the engine, so no running engine no lubrication to the output trans bearing. You go towing, even in neutral and you're spinning these parts and they'll fail.
Stick shifts don't have pressure lubed transmissions so it's not an issue. Most 4X4s have transfer cases that can be put in N and then the trans won't spin and they are lubricated like a manual trans so it's not an issue.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 04-19-2013, 09:45 AM   #1096
Originally Posted by f1100turbo View Post
I don't mention the sink cause we don't use it as such.
I've installed a pony keg oph coors light in the rear bunk and its plumbed to my beer dispenser. Ie the thing you called sink.
Just sayin
SWEEEET!!
Steve Dagro
sdagro is offline   Reply With Quote
Old 04-19-2013, 09:47 AM   #1097
Fulltime family RVer
Could we please move the TOAD discussion to its own thread?
Old 04-19-2013, 10:22 AM   #1098
Phat Phrog
RVChick's Avatar
UPDATE:
PROBLEM:
STEPS TO RESOLVE:
Thanks for the pic! That is the same set I have! Have not installed yet....go figure....but good to see how to reset if I have problems!
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 04-19-2013, 10:48 AM   #1099
Herk7769's Avatar
I have! Thank you so much. What a great tip.
HAM CALLSIGN - KC3FFW
Old 04-19-2013, 11:04 AM   #1100
Barney1's Avatar
I have my moments.
Although few and far between.
Barney
awning, led pad
