Old 04-19-2013, 03:32 PM   #1101
crunchman12001's Avatar
Originally Posted by Barney1 View Post
UPDATE:
I received my LED light strip yesterday (Apr 18th) that is 8 days from Hong Kong. I can really complain about that.
PROBLEM:
On the shake down test the light strip didn't work properly.
The blue LEDs on the strip are always ON when there is power to the unit.
^ Oh look the sad emoticons are blue, how apropos!
STEPS TO RESOLVE:
I contacted the eBay seller. After some back and forth troubleshooting the eBay seller sent me the reset procedure for the 44 Key LED strip controller (part# 073-004). NOTE: You won't find the part# on the controller.
I will post the rest procedure below.
For me the reset did not work.
Form this the dealer is concluding that the fault must be with the strip. The have offered to send me a new LED strip at no charge. I said sure.
I am now in wait mode again
Here is the reset procedure
HERK PUT THIS IN YOUR LIBRARY.
Thank you for the picture on the controller reset procedure. Glad it worked for you!
Question for you...What all does the reset do? Does it just reset the controller back to the factory settings or does it take out the features like jump, flash ect?
Although my LED's are working fine now, maybe this would also work to reset the DIY 1-6?
I have not played with mine much yet.
TIA,
crunchman
2015 F-250 FX4
Old 04-19-2013, 03:38 PM   #1102
Barney1's Avatar
Actually the reset did not work for me. The supplier thinks my problems is with the actual LED light strip.
The reset sets the controller back to factory defaults.
Barney
2012 Rockwood Roo 233s
2011 Ram 1500 Big Horn V8 Hemi
Previous Trailer -> 1996 Jayco 1207
Barney1 is offline   Reply With Quote
Old 04-19-2013, 03:43 PM   #1103
I am sorry, I re-read your post and I thought you said it worked. Thanks for the info about the remote.
Hope your boat from Hong Kong gets here quickly for you.
crunchman
2015 F-250 FX4
Old 04-19-2013, 09:21 PM   #1104
My fw is still in storage stop can't test but is the orange light by the door 12vdc? I installed these last year but just plugged into 120 outlet outside outlet, would like to have hooked to 12vdc and on switch.
2006 Rockwood 8280ss
biggie is offline   Reply With Quote
Old 04-19-2013, 09:26 PM   #1105
TURBS's Avatar
Yes the porch light is 12v.
Old 04-20-2013, 04:32 AM   #1106
LKicklight's Avatar
Bug Light
On our Crusader 270RET, the bug lite is right at the end of our awning, which is right over the door..with that said, I took all the stuff out of the light fixture and replaced it with the little white box, the ant. wiring and the DC lead tapped into the wiring, which is controled by the switch on the interior..The ant. lead sticks out a small hole that I drilled and caulked, along with the LED Wiring lead I also drilled out and caulked...there is a small amount of wiring from the light box to the LED;s, by placing a Ty-Wrap achor pad, you can hold that down along with the Ant. Lead done the same way..I know a picture is worth more that words...plan on finishing that up this morning..right now its 37 degrees here in Dallas, GA...winters back..
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 04-21-2013, 04:58 PM   #1107
Got home today to the project materials. Had in my mind that the install would be easy by mounting below awning with routing the wiring down the power awning channel and entering the interior at that spot.
However, I can't find where the awning wires enter the RV. By all views, it should be under the dresser, but I can't get access to the area unless I'm missing something. Is anything removable from what you see or do you have any suggestions?
2012 CC 30RL
edit1: still waiting for photos to upload to dropbox. Will update shortly.
2007 Chevrolet Silverado 2500HD Duramax Diesel
2012 Cedar Creek 30RL
Full Timers Since October 2012
RenoRock is offline   Reply With Quote
Old 04-21-2013, 05:01 PM   #1108
Adony's Avatar
Ready to start this install ALMOST...
After reading 111 pages of comments and suggestions on this project I have the materials in hand and am ready to start making it happen.. I just have one question (at this time) left to resolve. I have decided to mount the strip on the trailer (under side of the awning) vice on the awning roller. Where are you installing your lights? On the underside of the awning / drip rail facing down or just under the lower edge of the awning/drip rail on the aluminum trailer side facing out? Hopefully my picture will explain my question..
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 04-21-2013, 05:06 PM   #1109
I mounted mine on the bottom of the rail that holds the awning material.
Old 04-21-2013, 05:12 PM   #1110
Phat Phrog
RVChick's Avatar
Thanks OC....I am with Adony......just where on the underside works best. My LED lights came in, and ya know.....the adhesive is kinda sticky...but is it sticky enough to stay there during hot temps?
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is online now   Reply With Quote
awning, led pad
