Old 04-28-2013, 12:44 AM   #1161
Owner/Operator
RodeoGeorge's Avatar
On mine at the end of the wire there was a square piece with a half cylindrical surface, with the opposite side flat. The flat side goes against the wall (or whatever you're mounting it on) and the curved surface points out. That curved surface is the window through which the controller receives the IR beam.
If you're uncertain, take a piece of painter's tape, double it back on itself and make a two sided sticky. Temporarily mount the IR receiver and test.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 04-28-2013, 08:49 AM   #1162
PHS79's Avatar
I was thinking that was how the sensor was to be mounted, but just wasn't sure. Thanks again George!
Last night I took my DW and DD (3 years old) out to show them the lights. My DD said "daddy thats really cool!", its good to hear that a 3 year old and a 33 year old (me) think the same thing! haha
I just used the 3M tape that was already on the lights, I cleaned the area with alcohol twice then stuck the lights on. Our first camping reservations aren't for another 3 weeks, but then we have a 120+mile drive each way. I will report back on how the tape holds up.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 04-30-2013, 08:05 PM   #1163
LKicklight's Avatar
LED Step Lights
Someone ask me to submit a photo of our LED Step lights, cant; remember exactly who it was....here is a quick photo taken last weekend at Pigeon Forge, TN..This light is wired into the step lights on the inside that I also added at the same time..if one is on, then both are on....power came from the cargo light behind the step inside the cargo compartment..
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 04-30-2013, 08:07 PM   #1164
crunchman12001's Avatar
That was me. Looks like it lights the steps very well. Good job!
crunchman
2015 F-250 FX4
Old 04-30-2013, 08:16 PM   #1165
crunchman
Used led ribbon lights on the steps controlled with a dusk to dawn switch and wired into the step light. Also wired the awning lights to the same d to d switch.
Name:	LED Step lights 1.jpg
Old 04-30-2013, 09:00 PM   #1166
LKicklight's Avatar
LED Steps
This is a very good LED light assy., all inclosed for a good weather unit. there are four led's inside the lense cover...have two remaining...that what I like about this light, it is weather proof..
Kick
Old 05-01-2013, 12:01 AM   #1167
just got my led strip, was excited to see your idea and ordered same day I saw your post. Now I'm going to install. How did you handle the power plug in with the small power converter? Did you just use an outdoor extension chord? How did you attach or string the power chord and controller?
HappyCampers2
2011 Forest River Surveyor Sport 240
happycampers2 is offline   Reply With Quote
Old 05-01-2013, 12:04 AM   #1168
Wonderiing how you wired this. Mine has a power converter plug in. How did you power the strip? What gauge wire did you use if any? Newbee here, just trying to figure this stuff out.
Old 05-01-2013, 01:46 AM   #1169
Owner/Operator
You need to spend some time reading the posts in this thread. All your questions have been asked before, and there are numerous solutions.
Basically, the majority of the people that have installed the LED Strip Lighting use the RV 12V system to power the controller. Very few have used the "wall wart" and connected it to 110V AC.
RodeoGeorge
Old 05-01-2013, 08:13 AM   #1170
LKicklight's Avatar
End Connectors
where did you purchase your end bare end connectors and your silicon end caps?
awning, led pad
