Old 05-09-2013, 09:37 PM   #1241
QuietTimes's Avatar
Question
Like Herk and others will attach under the awning rail and run the wire down the awning support and into the pass thru.
I have identified a wire that feeds power to the hitch light. I have cut into that and run a wire over to where I will put the controller. However now that that is done not sure I connected in correctly.
I cut the red wire - so now have two ends. Then attached the end of the new red wire and nutted all three together. Ditto for the white wire. The hitch light works. But in doing this I blew a fuse. After replacing the fuse the red LED beside is still lit up.
What did I do? Is there some reset I should do? Maybe hit the battery disconnect then reconnect? Yikes hope I didn't blow something in the power panel.
Thanks...
Heather & Jim
2012 Ford F150 EcoBoost
2013 Rockwood 2703WS
Days camped 2012 - 14 (not enough); Days camped 2013 - 41 (May - 3; June-16; July-10; Aug.-12) Still not enough...
Days camped 2014 - 23
QuietTimes is offline   Reply With Quote
Old 05-09-2013, 09:47 PM   #1242
Tonk Mom's Avatar
LKick, thanks so much! You are totally awesome.
Jill
Jill and Ed and the kitties
1998 Coachmen Leprechaun 31Q
Tonk Mom is offline   Reply With Quote
Old 05-10-2013, 02:58 PM   #1243
Adony's Avatar
Finally Finished but NOW???
After digesting all of the information on this forum, I finished my finished the insdatllation of the light strip on my TT... I opted to install a dummy light fixture on the side of the trailer to use as a electronics box to hold the IR Sensor / receiver. Just before I attached the light strip with 2 sided tape I tested everything and it was a GO!.. I carefully attached the light strip being cautious not to bend or twist it in any way.. Once installed, I turned things on, and everything still worked OK with the exception of when I selected full GREEN when a small segment failed to light (less than 2 inches).. when other colors or shades were selected with the remote, these very same LEDs came on with the color selected and looked normal.. ONLY DARK GREEN WON'T ILLUMINATE... If it is something simple that I can fix, I will, BUT since everything else works fine, I won't hassle trying to undo the 3-m tape job that holds it up.. I have attached a picture of my Junction Box/Dummy Light and a picture of the light strip on GREEN... Any ideas or should I just carry on smartly and avoid Green?
ID:	30066   Click image for larger version
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 05-10-2013, 05:23 PM   #1244
crunchman12001's Avatar
Hi,
I would leave them be, unless green is your favorite color?
Nice clean install. Looks nice!
crunchman
2015 F-250 FX4
Old 05-10-2013, 05:40 PM   #1245
Owner/Operator
RodeoGeorge's Avatar
Sounds like the controller chip for that segment of LEDs has failed on the Green input. It could be an open (separation) in the printed circuit trace leading from the Green conductor to the chip. With solid Green selected, you might try applying pressure on that segment of the LED strip flexing it as much as possible and see if the Green comes on. If so, you'd need to do some coating removal and fine soldering to attempt to bridge the open.
The other option would be to go to the cut lines on each side of the "Greenless" segment, cut that segment out, and solder in a good segment.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 05-10-2013, 06:32 PM   #1246
Phat Phrog
RVChick's Avatar
You guys are so smart and creative!
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 05-11-2013, 12:05 PM   #1247
Adony's Avatar
Will let it ride...
I have decided to let the small area without dark green stay as-is... I have another segment that I could put in but who knows what damage I might inflict by trying to remove the strip from the 3-m double sided trim tape.. that stuff really sticks..
Ted
2010 T25KS Wildwood
2006 F-250 SD
Old 05-11-2013, 12:06 PM   #1248
zs325RES's Avatar
Good looking install.
I did something I haven't seen yet on here (I think) and thought I'd share.
I wanted my LED strip on my awning tube, so I know I needed to hook it up after the awning was deployed. I already have an extension I bought from Amazon, and also wanted to utilize the outdoor light above the door for simplicity, but did not want to take it off or modify the internals to tap power so I can use the light as stock again if needed.
My brain fart is this - I used a spare bulb, broke off the glass and removed the filament, then soldered the included adapter plug to the exposed leads making sure I used heat shrink tubing to insulate them,
This is what it wound up looking like - pretty simple really.
Then just placed it all in the housing with the 4 pin connector and IR detector hanging out of a small hole in the bottom of the housing. I just need to silicone up the hole, and done.
I already tested it and it works great. Maybe this will help other forum members.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 05-11-2013, 12:30 PM   #1249
Adony's Avatar
Awniing Tube Attaching
How did you attach your light strip to the awning tube? Tape or a temporary mount of some kind?
Ted
2010 T25KS Wildwood
2006 F-250 SD
Old 05-11-2013, 12:51 PM   #1250
Herk7769's Avatar
I had this problem with one segment of my first strip. Although all worked fine before I mounted them; when I stuck them up one of the leds was not making good contact with the printed circuit. (there are 4 pins on each led cluster).
I believe it was a cold solder joint.
I pressed on each one until I found the one that lit up when I put pressure on it.
Once it lit up, it worked until I moved the trailer. I had to repeat the pressure after every stop to get it to work for about a week. Suddenly "It is fixed" and have had no trouble now for over a year of camping.
I think the cold solder joint is now "mooshed" together and making good contact.
HAM CALLSIGN - KC3FFW
awning, led pad
