Old 05-11-2013, 03:19 PM   #1251
What kind or gauge of wire did you use on a power awning and how or where did you thread it to connect to the trailer. I've got the LED strip, but can't figure out how or where to attach power. I'm a newbee so give some detail. Thanks.
happycampers2 is offline   Reply With Quote
Old 05-11-2013, 05:19 PM   #1252
LKicklight's Avatar
Cargo Hole
Just finished installing two three Bright White Led Ribbon Strip lights in the cargo hole...The factory only had one light in the cargo area, the other was in the service compartment...now with 300 LED's I believe this will solve my problem...Can't wait until it gets dark to go out and test it...Still have some more LED's to install...One goes in the pots and pans compartment for DW...the other around the inside of the compartment under the bed....think that will about do it for a while..
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 05-11-2013, 05:26 PM   #1253
Herk7769's Avatar
I used telephone wire (4 conductor) to connect the lights to the control. I used some red and black 2 wire I had in the garage for the 12 volt DC. It only needs an amp or so and wire size is not all that relevant for the power. Look at the 12 volt pigtail they give you. Anything bigger than that is overkill.
ID:	30166   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 05-11-2013, 07:55 PM   #1254
zs325RES's Avatar
Originally Posted by Adony View Post
How did you attach your light strip to the awning tube? Tape or a temporary mount of some kind?
Just regular double faced tape. I didn't go with the fancy outdoor tape, as I don't expect it to get very wet. I can always change it later.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 05-11-2013, 09:06 PM   #1255
Herk7769,
Where did you install the strip on the exterior. I've seen some attached to the trailer just under where the awning rolls up to store, others in the barrel of the awning when it is extended. Looks like your's is on the side of the trailer from the installation pic you took. BTW, great response with the pic attached, I see that the sensor poretion of the control is the only thing on the outside. If your's was installed in the barrel of the extended awning, how did you afix the long wire?
Thanks,
Happycampers2
Old 05-11-2013, 09:18 PM   #1256
Herk7769,
Thanks,
Happycampers2
Herk and a few of us mounted them on the bottom of the rail holding the awning, not on the fiberglas side of the camper.
Old 05-11-2013, 09:29 PM   #1257
Missing Link
cyclepuck's Avatar
Originally Posted by zs325RES View Post
Good looking install.
I did something I haven't seen yet on here (I think) and thought I'd share.
I wanted my LED strip on my awning tube, so I know I needed to hook it up after the awning was deployed. I already have an extension I bought from Amazon, and also wanted to utilize the outdoor light above the door for simplicity, but did not want to take it off or modify the internals to tap power so I can use the light as stock again if needed.
My brain fart is this - I used a spare bulb, broke off the glass and removed the filament, then soldered the included adapter plug to the exposed leads making sure I used heat shrink tubing to insulate them,
This is what it wound up looking like - pretty simple really.
Then just placed it all in the housing with the 4 pin connector and IR detector hanging out of a small hole in the bottom of the housing. I just need to silicone up the hole, and done.
I already tested it and it works great. Maybe this will help other forum members.
Same way I did mine.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 05-11-2013, 10:11 PM   #1258
Herk7769's Avatar
Picture is worth a thousand posts...
ID:	30187   Click image for larger version
ID:	30188   Click image for larger version
ID:	30189   Click image for larger version
ID:	30190   Click image for larger version
Name:	Camper and Ohio AF Museum 2012 018.jpg
Old 05-12-2013, 06:51 AM   #1259
SHOW OFF !! It looks great as usual.
grayfox is offline   Reply With Quote
Old 05-12-2013, 06:59 AM   #1260
Herk7769's Avatar
Thanks. By using the bottom of the awning attachment rail, the LEDs are pointed kinda down and not straight out (side mounted). Careful placement will allow a double strip if you want to.
The wall mounted one's I have seen have had a lot of glare when looking towards the camper (IMO).
I have not seen a tube mounted set, but if installed in the slot some of the light looks like it might be blocked and the accessory slot would be unavailable for sun screens or other cool accessories.
awning, led pad
