Old 05-12-2013, 07:24 AM   #1261
cstover's Avatar
I like having mine in the awning slot. Allows a degree of aiming with my power awning. I can extend it a little less and aim at the camper, or extend a little more and aim towards the ground.
cstover is offline   Reply With Quote
Old 05-12-2013, 07:34 AM   #1262
The only 2 drawbacks are when the awning is stowed, no lights and having to plug & unplug when deploying & stowing.
Old 05-12-2013, 02:52 PM   #1263
Spidey82's Avatar
Back yard camping with my new LEDs
ID:	30251   Click image for larger version
ID:	30252   Click image for larger version
ID:	30253   Click image for larger version
Spidey82 is offline   Reply With Quote
Old 05-12-2013, 03:10 PM   #1264
TURBS's Avatar
We have nothing but time while camping right ?
If the awning is stowed then I don't need lights
Old 05-12-2013, 03:54 PM   #1265
Not necessarily if you are just staying overnight on a trip to FL like we do or on a trip somewhere else.
Old 05-13-2013, 03:14 PM   #1266
Adony's Avatar
Good Call
Originally Posted by herk7769 View Post
I had this problem with one segment of my first strip. Although all worked fine before I mounted them; when I stuck them up one of the leds was not making good contact with the printed circuit. (there are 4 pins on each led cluster).
I believe it was a cold solder joint.
I pressed on each one until I found the one that lit up when I put pressure on it.
Once it lit up, it worked until I moved the trailer. I had to repeat the pressure after every stop to get it to work for about a week. Suddenly "It is fixed" and have had no trouble now for over a year of camping.
I think the cold solder joint is now "mooshed" together and making good contact.
I tried as you suggested, and I got the 3 segments to light Green. Don't know how long it will last but I know where to go to fix it now.. Thanks .
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 05-15-2013, 06:09 PM   #1267
Does anyone have any idea about the life of the lights? For example, keeping it on all night - are they time limited?
2007 Chevrolet Silverado 2500HD Duramax Diesel
2012 Cedar Creek 30RL
Full Timers Since October 2012
RenoRock is offline   Reply With Quote
Old 05-15-2013, 06:28 PM   #1268
SYE
SYE's Avatar
Well I am very disappointed. The Domestic LED light strip kit $175.00 lasted from October until last weekend. About an inch from the plug they got hot and melted. What a piece if crap for 175. I will stick with the other ones I received from china for 25 bucks they still work!!"
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 05-15-2013, 07:02 PM   #1269
QuietTimes's Avatar
Tape Problem
Well after reading all the posts here I got my lights, did the prep work in the pass thru, cut my lights to length and siliconed the end.
Tonight was the "install" the strip night. EXCEPT the outdoor fancy 3M super sticky tape will not stick to my light strip. Sticks to anything else, just not the strip.
My strip is totally encased in a silicone sleeve. I am trying an experiment with a short piece. Ran some silicone seal on the strip then put the piece of 3M tape on it. Will check in the morning and see if it has good adhesion. If that doesn't work I'm stumped.
Ideas anyone?
Heather & Jim
2012 Ford F150 EcoBoost
2013 Rockwood 2703WS
Days camped 2012 - 14 (not enough); Days camped 2013 - 41 (May - 3; June-16; July-10; Aug.-12) Still not enough...
Days camped 2014 - 23
QuietTimes is offline   Reply With Quote
Old 05-15-2013, 07:39 PM   #1270
LKicklight's Avatar
Two Face Tape
Home Depot and Lowes has a two faced tape product this is sold in there countertop department..the product is used with the BackSplash Products by Fascade..comes in several different patterns an colors...Used the tape on my LED light installation for my cargo compartment...the first string would not stick even though I wiped the services down with alcohol twice...used the tape, all is well:
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
awning, led pad
