Old 05-15-2013, 07:48 PM   #1271
Originally Posted by QuietTimes View Post
Well after reading all the posts here I got my lights, did the prep work in the pass thru, cut my lights to length and siliconed the end.
Tonight was the "install" the strip night. EXCEPT the outdoor fancy 3M super sticky tape will not stick to my light strip. Sticks to anything else, just not the strip.
My strip is totally encased in a silicone sleeve. I am trying an experiment with a short piece. Ran some silicone seal on the strip then put the piece of 3M tape on it. Will check in the morning and see if it has good adhesion. If that doesn't work I'm stumped.
Ideas anyone?
Are you using this 3M tape and wiping everything down with acetone?
Old 05-15-2013, 07:59 PM   #1272
Tonk Mom's Avatar
How many of you put the LED's on the actual awning overhang under the fringe and how many of you put them on the side closest to the RV wall?
Jill
Jill and Ed and the kitties
1998 Coachmen Leprechaun 31Q
Tonk Mom is offline   Reply With Quote
Old 05-15-2013, 08:00 PM   #1273
QCCowboy's Avatar
I just used the tape that was on the back of the lights and granted it took two of us to get it up there because the weight of the yet-to-be stuck on end kept pulling the rest down. Once it was up there it was sturdy, but I did apply a bead of silicone to both sides of the lights every couple of feet and a enough to cover the ends thoroughly to keep it there. So far it has held up through about 50 miles of towing at 65mph with no problems.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 05-15-2013, 08:40 PM   #1274
SYE
SYE's Avatar
Ideas anyone?
3m makes an automotive trim molding adhesive that works awesome. I might be able to get t he part number for you.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 05-15-2013, 08:47 PM   #1275
Phat Phrog Stunt Crew
awwall's Avatar
Finally got mine up today. Used the 3m tape below and it worked like a champ. Only 1/2" wide....
3M Outdoor Insulator Film Mounting Tape, .5-Inch by 13.8-Yard (2175C) - Amazon.com
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 05-15-2013, 09:38 PM   #1276
PHS79's Avatar
I bought the 3M molding tape at Advance Auto parts, a 15ft roll was just over $11 with tax.
We have our first trip this coming weekend, about 105 miles of interstate each way. So we will see how 3M tape that came on the light strip holds up to that... I put the roll of molding tape in the truck along with one of my work platforms, just incase I have to remount the lights when we get to the CG, hopefully not, but I would rather have the stuff and not need it than need it and not have it!
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 05-15-2013, 09:42 PM   #1277
QuietTimes's Avatar
Thanks for all the ideas. The problem seems to be getting something to stick to the silicone. I'm not using the RGB 5050 that most of you have. It's called Dream 6803. The strip is loosely encased in a silicone sleeve. There is no tape pre-installed on the back of the tape. The exterior 3M tape - red protection on both sides - grey super sticky stuff is the actual tape I'm trying to use. Seems like it should stick like crazy but you would think it was greased the way it won't stick to the silicone sleeve. And yes I wiped down with acetone.
The experiment of putting a bead on the strip then sticking the tape to that seems to be holding. I won't pull hard till it has more time to set up.
Heather & Jim
2012 Ford F150 EcoBoost
2013 Rockwood 2703WS
Days camped 2012 - 14 (not enough); Days camped 2013 - 41 (May - 3; June-16; July-10; Aug.-12) Still not enough...
Days camped 2014 - 23
QuietTimes is offline   Reply With Quote
Old 05-16-2013, 07:38 AM   #1278
Phat Phrog
RVChick's Avatar
Originally Posted by LKicklight View Post
Home Depot and Lowes has a two faced tape product this is sold in there countertop department..the product is used with the BackSplash Products by Fascade..comes in several different patterns an colors...Used the tape on my LED light installation for my cargo compartment...the first string would not stick even though I wiped the services down with alcohol twice...used the tape, all is well:
Wow is that backsplash a mod?
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is online now   Reply With Quote
Old 05-16-2013, 07:40 AM   #1279
Phat Phrog
RVChick's Avatar
Looks terrific!!!
Kenny n Karen
Old 05-16-2013, 07:41 AM   #1280
Phat Phrog
RVChick's Avatar
Let us know how it holds up.....and if you get any comments on how cool they are!
Kenny n Karen
awning, led pad
