Old 05-17-2012, 07:56 AM   #121
So I will have to do some type of electrical work with these lights, just can't plug them in & wallah?
Bandit7 is offline   Reply With Quote
Old 05-17-2012, 07:58 AM   #122
Yes, if you want to take them down every time. These guys are mounting them semi-permanent.
Old 05-17-2012, 08:35 AM   #123
Is everybody finding the adhesive backing enough to hold onto the fiberglass or aluminum or are you guys using something else?
2006 Rockwood 8280ss
biggie is offline   Reply With Quote
Old 05-17-2012, 08:44 AM   #124
Herk7769's Avatar
So far so good. Will let you know this weekend (photos coming too).
I did put a big glop of RTV on the end of the LED strip with the plugs to keep wind blast from pulling on the plug and peeling it off.
I hope it works.
HAM CALLSIGN - KC3FFW
Old 05-17-2012, 08:58 AM   #125
Herk7769's Avatar
Things that you need to do:
1) Cut the strip on the correct end using the built in jumper sections to the exact length you need. Not cutting there will cause the mis-cut section not to light.
2) Mount the light strip somehow to the camper or awning (using the strip that comes with double sided tape already attached; adding your own tape, or jamming it into the necessary slot.
3) getting 12 volt 1.2 amp power to the control box. This can be done by running a two wire (red and black normally) from a source like a 12 volt light fixture and wiring it to the short "pigtail" that plugs into the control box (supplied with mine).
4) OR if you want to plug it into an extension cord, buying the correct transformer (see below) and doing it that way.
Old 05-17-2012, 09:16 AM   #126
Rugged Brown's Avatar
I got some black lights and a disco ball. Any suggestions on wiring.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 05-17-2012, 11:17 AM   #127
miatared's Avatar
A Gimlet or two should get you wired.... (remember those...)
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 05-17-2012, 11:53 AM   #128
stevengb's Avatar
I guess we haven't camped in the kind of campgrounds you all do...
I just like to sit and relax around a campfire with friends and a cold beer....not sure I would appreciate camping next to a Las Vegas show with runway lights!
Steve and Michele Bassett
2014 Surveyor Select SV305
2005 Ford F250 Lariat SuperCab 6.0 TurboDiesel
stevengb is offline   Reply With Quote
Old 05-17-2012, 11:58 AM   #129
TURBS's Avatar
look at it this way at least youll know where ...........
a) the beer is if you run out.
b) the possiblitly of dancing girls are.
3)
4)
Old 05-17-2012, 12:58 PM   #130
rotorhead1250's Avatar
Did I miss a price on these? At work so no ebay.
rotorhead1250 is offline   Reply With Quote
awning, led pad
