Old 05-22-2013, 07:22 PM   #1301
Fulltime family RVer
Originally Posted by LKicklight View Post
After you cut the LED's to the length you require, some folks try to use them in other places by soilering the ends...here is a much easier way and it looks nice too...
I'm anti-solder... Where do you get these clips?
Old 05-22-2013, 07:36 PM   #1302
crunchman12001's Avatar
Here you go:
For RGB 5050 LED LED PCB Connector adapter 4-Pin No soldering 10mm for 5050 LED RGB Strip | eBay
For single color: 5050 10mm Connector LED PCB Connector Adapter 5050 Single Color LED Strip 2 Pins | eBay
crunchman
2015 F-250 FX4
Old 05-22-2013, 08:03 PM   #1303
LKicklight's Avatar
http://www.ebay.com/itm/10PCS-10mm-2...-/121079701660
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 05-22-2013, 08:43 PM   #1304
Just wondering if anyone has installed lights below the awning on a Georgetown XL 378 with a power awning? If you have, where did you pull the power from?
Marty
2007 Georgetown XL 378
"EZE-TOW" Dolly
2010 Toyota Prius
mkaminski is offline   Reply With Quote
Old 05-23-2013, 10:19 AM   #1305
Love the lights
I really liked how the lights looked on your awning. It really added a nice touch. I like the different type of lighting.
SugarhouseAwning is offline   Reply With Quote
Old 05-23-2013, 10:35 AM   #1306
Taylorgso's Avatar
When all else fails, I turn to a product called "Amazing Goop" - works when 3M tape, or two-side velcro does not - just follow directions. Comes in several different colors - buy the one in the blue tube! This stuff hardens rock hard - I've used it to bond attachments to dashboards on several cars - it has never released from any of them. Removes with Acetone. Stuff is generally available at home supply stores, or at Advance, Autozone, etc. You can also use it to bond velcro to those surfaces - use the non-stick velcro, though.
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 05-23-2013, 11:29 AM   #1307
X2. Pulled my hair out fighting with various sticky-tape products. Then I found Amazing Goop. My first application is still holding strong after 13 years (in the Texas heat).
Old 05-28-2013, 06:08 PM   #1308
Does anyone know if these can be cut to length?
5M 5050 RGB Dream Color 6803 IC LED Strip Light Waterproof 133 Change RF Rmote | eBay
Marty
"EZE-TOW" Dolly
2010 Toyota Prius
Old 05-28-2013, 06:16 PM   #1309
PHS79's Avatar
Looking at the one picture on the bottom, yes it has the cut/split points in the strip.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 05-28-2013, 06:46 PM   #1310
Which lights have White???
I have gone through two sets of lights that I bought on Amazon. Both sets had white lights and they were held on to the awning bar with the double sided tape. Unfortuneately, both sets died after only a few weeks. So I then ordered the lights that everyone seems to be getting on Ebay. I was hoping to just be able to slide them into the awning track without using the double sided tape-and I was hoping for white lights. Well, my lights came today. It says white on the remote-but there is no white. I am hoping that of all you folks out there that have raved about these lights-which ones have a WHITE light setting and can just be slid into the awning rail track? Any info would be greatly appreciated!!
dec1952 is offline   Reply With Quote
awning, led pad
