Old 06-13-2013, 06:01 PM   #1401
Resident Masshole
force's Avatar
Maybe, but $8 with free shipping and < 1 week ETA from New Jersey works perfectly for me. Thanks again for that link!
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
Old 06-13-2013, 09:50 PM   #1402
Try this mini RGB controller to replace factory LED strips with RGB strips. It is small and fits behind the awning upright valence that hides the power wire. Also allows you to use the factory power switch for the lights. I put heat shrink around mine just to keep it dry. It is RF as well and works from a decent distance.
Hog Hunter is offline   Reply With Quote
Old 06-13-2013, 09:54 PM   #1403
Old 06-14-2013, 01:42 PM   #1404
grege's Avatar
Originally Posted by Hog Hunter View Post
Attachment 33087
Well that sure is tiny. Anybody try using it yet?
'12 Ford F150 Lariat Super Crew
'17 Grand Design Imagine 2800BH (Previous '13 Roo 21SS)
2016 Nights camped: 7
2015 Nights camped: 21
2014 Nights camped: 18
2013 Nights camped: 26
grege is offline   Reply With Quote
Old 06-14-2013, 02:16 PM   #1405
Owner/Operator
RodeoGeorge's Avatar
I am using one of these for ONE of my LED Strips (have 2 awnings on the 8289WS). I wished that there was a way to use more than one, but they operate on the same frequency with the same codes, so only one can be used without interference and unpredictable results.
I evaluated 5 different RF Controllers, and this one I rated #1.
The review is Post 1009 in this thread.
My solution to awning lights
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 06-14-2013, 03:09 PM   #1406
TURBS's Avatar
Originally Posted by Barney1 View Post
I now have two remote controls so the DW and I can fight over colour
Your not alone brutha !
Old 06-14-2013, 08:04 PM   #1407
mudshark's Avatar
I purchased from eBay a continuous 10m strip of 5050 LEDs 60/meter. I need about 6m for under my awning and wanted one continuous strip. The place i got them from (greenandless) said that the 10m strips of 60/m have a wire inside the strip that goes to the other end of the strip to power that end due to the amount of LEDS, length of strip and as a result a drop in voltage. The 30 LEDs/ meter strip don't have this problem.
He told me that I should be safe to cut the 10m strip and use a 6m long strip without any dimming of the LEDS (voltage drop) There are amplifiers you can buy for about 8 bucks to make 2 normal 5 meter strips together instead of the 10meter strip with the extra wire inside. He said anything longer than about a 7meter strip you'll notice the dimming if it doesn't have power to the far end via internal wire or amplifier.
I plan on using the 6m strip under the awning, purchasing another control unit, remote and AC adapter and using my leftover 4meter strip somewhere around the house.
Also if you do use a cut strip you can order end caps from eBay. Be sure to cut at the marked cut lines. Hope this helps.
mudshark is offline   Reply With Quote
Old 06-15-2013, 10:13 PM   #1408
PineForestCamper's Avatar
Hung the LED strip today and have a slight problem.
Cut the hole into the camper. CHECK
Hung the strip on the piece underneath the awning against the camper. CHECK
Spliced wires together and waterproofed using shrink tubing. CHECK
Pushed wire into camper thru bushing and sealed with silicone. CHECK
Wired into 12v near bunk fan. CHECK
I turned on lights every step of the way to verify everything working properly. All good. Then the job is finished and I turn it on to take a look at what had been a up to that point flawless job and notice that when using the 44 button remote that when I use any color in the white button row the closest three LED's to the line that heads into the camper will only stay on GREEN. Hmmm. Any other color under BLUE, GREEN, & RED rows work perfect. Has anyone ever come across this? Is there a fix? I have posted a picture of all blue which works great and all white which you are seeing the three LED's on the right in GREEN. Grrrr.
I am using a 5050 strip with the 44 remote.
ID:	33281   Click image for larger version
2009 Chevy Silverado/2500/6.0/3.73/CC
2016 Keystone Outback 250URS
2013 Rockwood Roo 233s (SOLD)
http://instagram.com/pineforestcamper#
PineForestCamper is offline   Reply With Quote
Old 06-15-2013, 10:22 PM   #1409
Herk7769's Avatar
Sounds like the strip might be finding a ground.
I would look for a bare spot on the strip at the farthest malfunctioning light segment from the power connector.
HAM CALLSIGN - KC3FFW
Old 06-15-2013, 10:50 PM   #1410
Bingo. Good call Herk. So I started pressing on each of those three LED's with my finger and the one closest to the power is the culprit. I press in on a spot around that one and then those three do as they are supposed to. Once I pull my finger off that spot they go back to green. I am unable to notice anything particularly different there that would stick out. Any suggestions? I would even take a suggestion that would deaden those three but leave the others on. Problem is power runs past these three. Sighs.
awning, led pad
