Old 06-23-2013, 05:50 PM   #1441
B47
Originally Posted by herk7769 View Post
Only problem with the doubled up light strip is if there are two campers facing each other it could attract aircraft at night!
DEET does not repel Cessnas.
Very good.
Old 06-23-2013, 08:08 PM   #1442
Phat Phrog
RVChick's Avatar
Originally Posted by Camping Buddys View Post
Just installed a second set, did order the 2nd one late at night and it was the wrong one! Will use one set (3528) for the outside kitchen and the 3rd set under the awning to match the 5050. Yes, had to order a 3rd set!
Long trip next week, so the lights (3m tape) will be tested on the road. (7hrs trip)
I love how you have it going down the entire side!! Looks great!
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 06-23-2013, 09:40 PM   #1443
Camping Buddys's Avatar
Thanks!
ID:	33880   Click image for larger version
John, Lilly & the kids.
2013 Surveyor Select SV 305
2011 Toyota Tundra crew max 5.7
http://campingbuddys.shutterfly.com/
Camping Buddys is offline   Reply With Quote
Old 06-24-2013, 09:41 AM   #1444
Barney1's Avatar
Originally Posted by Adony View Post
After digesting all of the information on this forum, I finished my finished the insdatllation of the light strip on my TT... I opted to install a dummy light fixture on the side of the trailer to use as a electronics box to hold the IR Sensor / receiver. Just before I attached the light strip with 2 sided tape I tested everything and it was a GO!.. I carefully attached the light strip being cautious not to bend or twist it in any way.. Once installed, I turned things on, and everything still worked OK with the exception of when I selected full GREEN when a small segment failed to light (less than 2 inches).. when other colors or shades were selected with the remote, these very same LEDs came on with the color selected and looked normal.. ONLY DARK GREEN WON'T ILLUMINATE... If it is something simple that I can fix, I will, BUT since everything else works fine, I won't hassle trying to undo the 3-m tape job that holds it up.. I have attached a picture of my Junction Box/Dummy Light and a picture of the light strip on GREEN... Any ideas or should I just carry on smartly and avoid Green?
Looks good. I see on a separate post you fixed your dead light issue.
What did you use to cover your wires going up the wall?
I would like to do something similar.
Barney
2012 Rockwood Roo 233s
2011 Ram 1500 Big Horn V8 Hemi
Previous Trailer -> 1996 Jayco 1207
Barney1 is offline   Reply With Quote
Old 06-24-2013, 04:26 PM   #1445
Cmmjmoore's Avatar
Well the camper lights are really cool and I love the brick driveway. Did u connect to together at the awning strut?
2013 SP 240 Anniversary
Tundra CrewMax 5.7L in Pyrite Mica
Clark, Mary Jane & Max our German Short-haired Pointer
(2011-42)
Cmmjmoore is offline   Reply With Quote
Old 06-26-2013, 11:47 AM   #1446
Sinchuwus's Avatar
Just a friendly inquiry, Can someone assist?
Originally Posted by Sinchuwus View Post
First off, kudos and thank you to everyone, (especially Herk) on this thread for your ideas and assistance, I have actually read this thread from start to finish prior to doing my camper and helping my buddy out. We did however run into a problem and I'm not sure if its similar to WarMovies issue, so here it goes. We are running our LEDs up the right side of the awning support next to the trailer, make the 90 onto the awning support at the top, make the next 90 and go down the left awning support. In order to do this we've had to splice two LED strips together using the LED Connector Box mentioned earlier in this thread. (BTW works like a champ!!!) The frist strand of LEDs lights up perfectly in all colors, the second strand of lights lights up perfectly in blue and red, however in white, pink and green we see sporadically different colors throughout the strand. I've attached a picture of the white as its the best to see what I'm describing.
These are the lights that we purchased: Waterproof LED Strand
Any help would be appreciated.
Just a friendly inquiry, has anyone seen this happen before?
Thank you for your assistance in advance.
-Sinchuwus
"Sinchuwus up, grab me a beer!!!
Sinchuwus is offline   Reply With Quote
Old 06-26-2013, 02:34 PM   #1447
TopGunz's Avatar
Thanks Wagon52, I'm new to this site so just ran across your solution to awening lights. I am ordering me a set now. Did you have to adhere the lights in the channel or do they stay in pretty good by just sliding them in?
TopGunz
SW Missouri
2013 Columbus 340RK
2011 Ford F350 DRW
King Ranch 6.7L Diesel
TopGunz is offline   Reply With Quote
Old 06-26-2013, 09:56 PM   #1448
CRZ
CRZ's Avatar
Just slide or push them into the slot.
CRZ is offline   Reply With Quote
Old 07-16-2013, 09:23 PM   #1449
David WAWA's Avatar
What is everyone using to install lights to your awning or camper? I tried heavy duty outdoor dbl sided tape that sticks well to everything except the silicone casing the lights are in. The size of lights do not allow me to slide in the grove of Awning. I like how a few of you guys installed on the camper right where the awning attaches to the camper,But cant get mine to stay. PLEASE HELP.
David WAWA is offline   Reply With Quote
Old 07-16-2013, 09:33 PM   #1450
I wiped the rail down with alcohol and used 3m outdoor double sided tape. The lights came with 3m tape on them that didn't stick very good until I used the 3m tape on the rail.
awning, led pad
