Old 07-18-2013, 03:35 PM   #1471
Displaced2's Avatar
And the cake recipe is where?
Displaced2 is offline   Reply With Quote
Old 07-18-2013, 04:12 PM   #1472
Phat Phrog
RVChick's Avatar
Hee!! I was hoping someone would ask!
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 07-18-2013, 05:15 PM   #1473
Displaced2's Avatar
Recently returned from Key West. Need I say more?
Old 07-21-2013, 11:36 PM   #1474
Leecountry's Avatar
I see everyone is using the 5050 lights but what guage wire are you using to get the power to them and what is the length of the wire run? I would like to get the 5050 lights but worried about the amp/current draw and would use about a 40ft piece of 18awg wire. Looks like they draw around 6 amps for 5 meters.
Leecountry is offline   Reply With Quote
Old 07-21-2013, 11:55 PM   #1475
QCCowboy's Avatar
I used some 18/4 wire (underground sprinkler wire) to go from the lights to the control box. My run is only about 12-15 ft though, just enough to go down the awning and inside to the basement where the control box is. Where are you running them from/to that would require a 40ft. run of wire? Just sounds like a really long run.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 07-22-2013, 12:05 AM   #1476
Leecountry's Avatar
Well I guess it's only going to be about 30 feet I'm running from the fuse box at the close to the rear of the camper to the front and out where the power goes out for the awning. I may just run from the the battery and put a fuse there if needed to keep wire length down
Old 07-27-2013, 10:10 PM   #1477
NCIC105's Avatar
Originally Posted by wagon52 View Post
Bought these LED strip lights off eBay. 3528 RGB SMD 5M 300 LED Strip Light Waterproof IR Remote 2A Power Supply | eBay
Wasn't sure how I was going to mount them. At first I thought I would put a Velcro strip on the awning tube and another on the light strip. That didn't work since the Velcro wouldn't stick to the LED strip. After looking at the strip lights I thought It looked like they would fit in the rail on the awning. Well they did! And better yet, they will roll up right in the awning. Take a look, I can get some closer pictures of them in the daylight tomorrow.
I would love some pics...How did you attach electric?
NCIC105 is offline   Reply With Quote
Old 07-28-2013, 12:11 AM   #1478
wagon52's Avatar
I just ordered wire, waterproof connectors and an RF controller from usledsupply.com. So now hopefully it will be a self contained unit that will always be hooked up. I also moved it from the awning tube to the side of the camper on the awning rail.
2012 Rockwood Signature Ultra Lite 8312SS
2008 Rockwood Roo 21SS (History)
1981 Starcraft Galaxy 2108 (its gone)
1999 Dodge Durango (Retired TT)
2006 Dodge Ram 3500 Quad Cab 4x4
wagon52 is offline   Reply With Quote
Old 07-28-2013, 09:06 AM   #1479
LKicklight's Avatar
Led's
Due to the overwhelming demand for these LED Awning lights, I am bringing an extra set just in case someone might want to install some while we all are there. These are the 16'-0/300 LED Ribbon Strip with controller and AC/DC Power Supply. Just in Case
kickstarter
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 07-28-2013, 12:11 PM   #1480
PHS79's Avatar
We just got back from camping and I noticed that I have a very slight problem. On one of the light clusters the green LED is not lighting up, red and blue work but just not the green. Its only the one light, about 7 from the cut end of my strip. Has anyone had this issue before? Does anyone have any idea what happen or if I can fix it?
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
awning, led pad
