Old 11-12-2013, 09:05 AM   #1531
Tonk Mom's Avatar
Okay, I will get 3M Automotive just in case. Thanks so much.
Jill
Jill and Ed and the kitties
1998 Coachmen Leprechaun 31Q
Tonk Mom is offline   Reply With Quote
Old 11-12-2013, 09:08 AM   #1532
SYE
SYE's Avatar
Originally Posted by Eric Bourlet View Post
Where can I get the dawn to dusk switch to work with the strip?
I got mine on ebay
Dusk to Dawn Light Control Sunset Twilight Switch Day Off. | eBay
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 11-22-2013, 08:45 PM   #1533
This thread has so many posts that I may have missed the answer to this question. So apologies if this has been addressed before.
The clear soft plastic that encapsulates the individual LED's on my awning lights has yellowed so that the white setting is nowhere as bright as it was when new.
Anyone else have this issue?? Is one brand better than another when it comes to yellowing??
Also, since I may be replacing my lights, I thought about those shown in this youtube video :
These are REALLY programmable compared to all the rest I've seen. Some of the modes I wouldn't even use unless I was running a bordello so some such!!!
Not sure where to find them though; anyone recognize the brand??
Boowho??
boowho is offline   Reply With Quote
Old 11-22-2013, 08:52 PM   #1534
Ford Idaho's Avatar
The plastic on the house Christmas lights yellowed out in less than a year.
Plastic is NOT very UV tolerant.
Old 11-22-2013, 08:59 PM   #1535
LKicklight's Avatar
Target
We were at Target this morning, looking through the Christmas lights on display, I came across a very nice 12'-0 LED Set that has a small controller similar to the ones we have all purchased from the web. The big difference was, this set was covered with a flexible clear covering that would protect them when being used out doors. Liked the design and construction of these lights, right up until I saw the price for the 12'-0 set, $89.99! Think I will keep my $16.00 5050 (32'-0) that I paid for this past summer, and is still working fine.
Boowho??
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 11-23-2013, 03:12 AM   #1536
crunchman12001's Avatar
Boowho??
I am sure the LEDS all have the same clear plastic covering on them but here is what you are looking for.
They are called New 5M 5050 RGB Dream color 6803 IC Waterproof LED Strip Light 133 Color Change
Some of the EBAY sellers are trying to get $100 bucks a set, this guy wants $30. They all seem to be the same from China.
crunchman
2015 F-250 FX4
Old 11-23-2013, 01:54 PM   #1537
crunchman
I tried the link you mentioned; that price appears to be ONLY the light strip itself.
Here's one I found that appears to be identical to the one in the you tube window:
[url=http://www.aliexpress.com/item/5050-RGB-SMD-Magic-Horse-Scroll-Racing-LED-Strip-Light-Chasing-54led-m-5M-81-Program/673715420.html[/url]
As far as yellowing, maybe a UV inhibitor (like 303) a couple of time per year would help??
Boowho
Old 11-23-2013, 02:04 PM   #1538
Iwannacamp's Avatar
FWIW. I ordered my lights from eBay also. I went on a previously mentioned post(at the beginning) and inquired about an order, but I had to use a credit card online from Chiba.. I was a little nervous about that. I referred mine and got then in. I ordered indoor lights to start in bright white. I have not installed then for undercounted lights, but that's my plan. I felt like PayPal was more secure and got them for about the same price. They came from China also.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 11-26-2013, 05:04 PM   #1539
Adony's Avatar
Now what has happened..
Up until our last camping trip, my 5050 LED lights under my awning rail have worked perfect.. this trip was something else.. Only some of the lights worked in varying numbers of leds illuminated.. You can see from the pictures below what I ma talking about... I made sure all connections were tight, and that full dc voltage was available to the controller. Before if try to remove the strip of lights and replace them (will be tough to do since I used 3-m auto trim tape to attach them with), I wanted to see if anyone had any experience or ideas what I might do. The lights were purchased on auction site as many others on this site have done.. maybe they are just cheap to begin with BUT... appreciate any ideas...
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 11-26-2013, 06:10 PM   #1540
Herk7769's Avatar
If water gets into the back of the LEDs or the resistors, the corrosion can alter the voltage enough (at the LED) to cause it not to fire. if this happens to one LED, the entire 3 LED section will not light that color.
The solution is to see if it comes back in dry weather or you can cut out a section and replace it using the special butt connectors available on eBay; you will need 2 per running section replaced.
10mm Width 4pin LED Connector Adapter for 5050 LED RGB Color LED Strip US Seller | eBay
I have a few feet that I did not use in my installation and will be using it to repair any burned out sections in mine. Make sure you use the correct alignment and not install the replacement upside down.
HAM CALLSIGN - KC3FFW
awning, led pad
