Old 01-23-2014, 02:59 PM   #1571
That is a great idea running them off the outside light. I think i may go that route!
danimal86 is offline   Reply With Quote
Old 01-24-2014, 12:10 PM   #1572
Hey Guys;
OK, I didn't read all 158 pages of this post but do have a question. I am thinking about purchasing am awning light kit. I think I found a way to run the wires to 12V. The kit is available with an RF remote which I think is cool. Lots of different colors, dimming etc. My question is: Can I add additional wire length? Instructions for these things are terrible. I am not familiar with this type of wiring. I plan on installing just under the awning on the rig wall and following the wire path for the awning to a constant 12V source inside the rig. I am guessing I will need about a 16 foot run of wiring. I am guessing I will have to install the LED strip, connect some required length of wiring, run that wiring, hook that wiring to the receiver and the receiver to the 12V source. Is that the way it works?
Thank for any help
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 01-24-2014, 01:44 PM   #1573
jtstromsburg's Avatar
Basically, yes. I put the led controller on the side of my camper near the lights, and then ran cheap 22g wire down the awning bracket and into the basement to a power source
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 01-24-2014, 02:12 PM   #1574
My first thought was to get the controller out of the weather and mount it in the basement. Am I correct that in doing it that way I would need to run this long 4 wire bundle with connectors through the rig? Where placing the controller near the strip means just running a wire pair to the 12V source? Do you have the IR or RF controller. Any issues with it or hanging on the outside?
Thanks Joel
Old 01-24-2014, 06:53 PM   #1575
I found a lens cover (not sure it's interior or exterior) , siliconed the controller and the cover over it, to the side of my camper. That way the controller is out of the elements and still easy to aim at. I don't have a rf remote, so line of sight is important
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
Old 01-25-2014, 07:00 PM   #1576
Adony's Avatar
Still Searching for ideas...
As you said, it appears that moisture was the cause of this problem.. The entire LED strip was labeled as waterproof on both the front and rear sides.. After I figure out how to remove the defective 15 ft strip that is attached using automotive double sided trim tape to underside of awning rail, I will replace it with another LED strip I have. Any suggestions on how to make sure that it is waterproof so this doesn't happen again. The new LED appears to be totally encapsulated in silicone like material, but so was was the last one. Again I am looking for suggestions to avoid this happening again..
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 01-25-2014, 07:45 PM   #1577
I would think if it's encased in a silicone type coating it should be fine. When I installed my strip, I siliconed the ends to help hold them down, and maybe it helps seal the strip up Also? Mine have been on for almost a year with no problems.
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
Old 01-25-2014, 08:23 PM   #1578
SYE
SYE's Avatar
I ran mine down the front awniong mount and into the trailer because thats where the plug was at and it is waterproof, and the remote control works great. I ran the light strip along the edge where the awning is mounted to the camper. Everything looks and works great!! It plugs in up in the front closet.
ID:	45389   Click image for larger version
ID:	45390   Click image for larger version
ID:	45391   Click image for larger version
ID:	45392   Click image for larger version
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 01-25-2014, 08:26 PM   #1579
LKicklight's Avatar
Covers
There is a metal track that is available that can be attached to the coach via the 3M tape. The LED lights lay in that metal track and then a clear plastic cover just pops over the lights into the track.
When I get my coach out of winter storage, I intend to covert mine to this and once again mount them directly under the Awning out of the weather: Have not had any problems as they are, just think the metal track application looks a lot cleaner and will protect them.
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 01-26-2014, 01:25 PM   #1580
Adony's Avatar
Moisture / type of LED Strip?
It appears that moisture coming in contact with the back side of the 15' LED Strip is most likely causing my problems. Various segments of the strip either don't illuminate or flicker when turned on. I plugged another "New" light strip into the controller and they work fine.. SO.. the old strip must come down.. Here is my question.. On both the old LED strip and the New one I have, the 4 copper attachment points on the cut lines ( every couple of inches or so) are exposed to the elements/double sided mounting tape. This tape holds moisture, thus the copper dots touch it... My question is: Is there a specific type of LED strip that is totally encapsulated on both sides.. or is there a specific type I should purchase to avoid this happening in the fuiture. It appears as though what I frst installed was made for indoor use but I could be wrong.. Need help... The picture I hopefully included shows the copper dots I am concerned with..
Ted
2010 T25KS Wildwood
2006 F-250 SD
awning, led pad
