Old 04-01-2014, 07:52 PM   #1671
grege's Avatar
I used the porch light housing, removed the bulb and socket, and attached power to that. I can turn them on and off using the porch light switch inside the camper. The controller is inside my porch light housing and the sensor sticks out the bottom. I got some very flat wire molding and went from the porch light to the bottom of the awning to run my wires to the lights.
Greg
'12 Ford F150 Lariat Super Crew
'17 Grand Design Imagine 2800BH (Previous '13 Roo 21SS)
2016 Nights camped: 7
2015 Nights camped: 21
2014 Nights camped: 18
2013 Nights camped: 26
grege is offline   Reply With Quote
Old 04-01-2014, 07:57 PM   #1672
LKicklight's Avatar
Exactly the Same
did ours the same exact way, has worked well no problems, good job!
Greg
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 04-02-2014, 05:01 AM   #1673
Who Dares, Wins
doc73's Avatar
Ok, so I am not going to lie... I have NOT gotten through the 100,000 pages yet just 100 or so... Those putting the left over scraps of LEDs in your compartments / pantries, how are you wiring them for power and color illumination? Do they need their own power supplies / control boxes separate from the lights on the awning? Or are they spliced in some which way? -Pat
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 04-02-2014, 07:52 AM   #1674
LKicklight's Avatar
One Bulb Install
the led lights can be a little over whelming at first glance. I would start off with one simple bulb and socket along with two wires for dc install. hook one end to the positive terminal of your battery and the other to the negative side. The light bulb should light up...LEDS ARE JUST THAT SIMPLE, think of all those led dots as one light bulb, they all share the same wire for power. Place an on-off switch in one of the wires to break they circuit, that's all there is to it..
Old 04-02-2014, 01:35 PM   #1675
Greg
Pictures?
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 04-02-2014, 01:38 PM   #1676
Jjs2000z's Avatar
Greg
My porch light is in the middle of the trailer. Do I have to re wire the led strip to accommodate this since the led wiring starts at the end of the strip?
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 04-02-2014, 02:30 PM   #1677
grege's Avatar
Originally Posted by pappcam View Post
Pictures?
I'm not in town right now with Spring Break. I looked on my phone but all I had was a video of the lights changing. I'll try and get some when I get back.
Old 04-02-2014, 02:36 PM   #1678
grege's Avatar
Mine is like that too. My LED lights had a short wire on each end that the factory soldered. (If not you can solder to the strip.) I cut the strip so I could use those wires in the middle. I also bought this piece that I used to go from the controller up my wire mold.
1pcs 1M RGB Extension Cable Wire Connector 4pin for SMD 5050 RGB LED Strip Light | eBay
I cut that wire to the length I needed and soldered the bare end to the wires from the LED strip after cutting off the connector. The other end then plugged into the controller.
Sorry I don't have pictures. I can try and get some when I get back in town.
Old 04-02-2014, 02:51 PM   #1679
Jjs2000z's Avatar
Yes pictures would be great
2014 stealth 2714
Old 04-03-2014, 09:17 AM   #1680
Who Dares, Wins
doc73's Avatar
I know how to "wire" them per se... But let me re-phrase my questions since I think I might not have been clear. When people are using the scraps for their step lights and compartments, do they all need their own control / power supply (if using the RGB LEDs) or are people just purchasing the single color lights for this usage. Or are people running the wires back to the one control box.
I have blue LEDs that came from the factory but might want to add the RGB. I would use the scraps to add in my compartments and pantry.
2015 ChevyHD D-Max
awning, led pad
