Old 04-03-2014, 09:48 AM   #1681
jtstromsburg's Avatar
I used the small pieces, wired directly to a 12v switch. No controller needed, but they are all on then. Just soldered 16g leads on the strips.
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-03-2014, 10:05 AM   #1682
Originally Posted by pappcam View Post
Pictures?
Light mod!Youroo!! Place controller inside drill hole for antenna on bottom of lens.
youroo is online now   Reply With Quote
Old 04-03-2014, 11:02 AM   #1683
Thanks but unfortunately my porch light is under the middle of my awning. I see others have the same issue so I'm hoping one of the people who have dealt with that situation can get some pictures up.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 04-04-2014, 11:29 AM   #1684
Adony, where did you get the covered all channel. I have looked at home depot an Lowes but no luck. Thank you in advance
Sent from my DROID BIONIC using Forest River Forums mobile app
jerryhowell is offline   Reply With Quote
Old 04-04-2014, 05:43 PM   #1685
grege's Avatar
Originally Posted by Jjs2000z View Post
Yes pictures would be great
Here you go. You can see the sensor coming out of the bottom of the light housing.
ID:	49123   Click image for larger version
'12 Ford F150 Lariat Super Crew
'17 Grand Design Imagine 2800BH (Previous '13 Roo 21SS)
2016 Nights camped: 7
2015 Nights camped: 21
2014 Nights camped: 18
2013 Nights camped: 26
grege is offline   Reply With Quote
Old 04-04-2014, 06:20 PM   #1686
Who Dares, Wins
doc73's Avatar
Sent by me
Thanks. That's what I was needing. -Pat
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 04-05-2014, 01:06 PM   #1687
I installed my LED lights this week. Cut access above the refrigerator on the outside under the awning and fished wire down to receptacle for refrigerator. Installed a blank white plastic plate with weather proof gasket then caulked it to ensure there is no leaks while driving in rain. Cleaned side with alcohol and attached LED strip to camper.
Works great, color changes with dim also.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 04-06-2014, 10:59 AM   #1688
Jjs2000z's Avatar
Thanks for the pics. Does the LEDs stick on the side of the RV?
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 04-06-2014, 11:12 PM   #1689
Yes came with double side tape. Drove 3 hours between 40 and 70 MPG 4 hours after installing them. Total install cost was around $ 80.
FYI if you have issue with double side tape you can get 3M VHB tape. This is the tape that they use to hold metal window seal strips on convenience stores like the BPs.
Old 04-06-2014, 11:45 PM   #1690
Jjs2000z's Avatar
I don't have the same bar below the awning to install these lights
2014 stealth 2714
awning, led pad
