All right.
If you were careful when you attached the first LED strip under the awning rail and followed the slotted awning material retainer, there is JUST enough room for a second strip!
I cut the sockets off the four wires of the two strips and soldered them to a piece of four wire TELCO solid telephone wire.
White (ground) to BLACK telco
Green (green Vcc) to GREEN telco
Red (red Vcc) to RED telco
Blue (blue Vcc) to YELLOW telco
Taped; heat shrunk; and gooped with RTV Silicone II for waterproofing and security. Ran the TELCO down the arm and into the motor power cord hole in the arm. In the Basement compartment I installed the new 44 IR remote module ad routed the IR sensor back out through the same hole.
I used the RTV to attach it to the bottom on the arm support.
No control switch is required since I can just reach into the compartment and yank the plug out when I am not using it.
The double strip of lights and all the new cool features just really rocks IMO. Plenty of light with the awning extended or rolled up.
AS I stated before get
http://www.ebay.com/itm/270939580723...fsrc=1&afsrc=1
or the same LED strip with the 44 IR controller.
http://www.ebay.com/itm/NEW-44-Key-I...item4ab81ea0c6
