Old 04-07-2014, 06:11 AM   #1691
grege's Avatar
Originally Posted by Jjs2000z View Post
I don't have the same bar below the awning to install these lights
Where I installed mine was actually part of the awning where it attached to the camper. You sure you don't have that area? You can see mine in a previous post picture. Take a picture looking up at your closed awning and we can give you some ideas.
Also, regarding the tape attached to the LED's. I installed some in my F150. In the bed I used 3M automotive double sided tape. It hasn't moved. Inside my center console storage I just used the tape from the LED's. That fell off within 6 months. Now I only use 3M tape when I install the LED's. YMMV
Greg
'12 Ford F150 Lariat Super Crew
'17 Grand Design Imagine 2800BH (Previous '13 Roo 21SS)
2016 Nights camped: 7
2015 Nights camped: 21
2014 Nights camped: 18
2013 Nights camped: 26
grege is offline   Reply With Quote
Old 04-09-2014, 11:19 AM   #1692
Jjs2000z's Avatar
Here is a pic of underneath my awning. I'm not sure if there is a spot available to stick the LED light stripClick image for larger version
Name:	ImageUploadedByForest River Forums1397060376.755599.jpg
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 04-09-2014, 01:20 PM   #1693
Here is a pic of underneath my awning. I'm not sure if there is a spot available to stick the LED light stripAttachment 49498
You can place it right under the awning strip. Go to your local Rev show or dealer you will see how they installing them on new rvs . I cut access I. Thge side and ran a wire down to the refrigerator power. See picture.
Sent from my Nexus 7 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 04-09-2014, 01:25 PM   #1694
Jjs2000z's Avatar
Should stick the led strip on the side just like you have it? I'm thinking about using the outside light for power.
If I stick it to the side of the RV like you have how bright is the light? Does it reflect downward?
2014 stealth 2714
Old 04-09-2014, 03:38 PM   #1695
realebill's Avatar
i installed my LED's about 1" below the metal rail on the side of the trailer. i attached my wires to the 12v source at the step light. i ran the wires through plastic wire molding up to the controller which i put in a weatherproof enclosure.
Name:	LED install.jpg
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 04-09-2014, 04:13 PM   #1696
Jjs2000z's Avatar
Can you include a pic of how bright it is at night with the led mounted on the side of the trailer?
2014 stealth 2714
Old 04-09-2014, 04:25 PM   #1697
Don't have a picture of how bright the lights are but if you have seen the rope light used it is just as bright or brighter.
Sent from my SCH-I545 using Forest River Forums mobile app
Old 04-09-2014, 04:58 PM   #1698
Jjs2000z's Avatar
I have this strip of led in my rZr and they are very bright. I'm wondering if I stick them on the side of the trailer will it reflect downward where I need the light to shine. Here is a pic of the led strip in my Rzr Click image for larger version
Name:	ImageUploadedByForest River Forums1397080686.599221.jpg
2014 stealth 2714
Old 04-09-2014, 07:45 PM   #1699
grege's Avatar
Hard to tell from the picture but are you sure you don't have a spot under the awning? I would think how awnings attach would be pretty common. My area is maybe 1" wide. I put it close to the camper in case I wanted to add another strip of lights. You only need about 1/2" of space.
I think the LEDs cover about 120 degrees. So if you did put them on the side of the camper I would think you would just have an area down on the ground next to your camper that might not get as much light.
Greg
Old 04-13-2014, 07:20 PM   #1700
BurgPath's Avatar
Got mine installed!
Got my LEDs installed.
Mods - BurgPaths Photos
Kevin (BurgPath)
2018 Grand Design Reflection 337RLS
2017 Ford F350 CCSB
Mods and Pics
BurgPath is offline   Reply With Quote
awning, led pad
