Old 06-10-2014, 10:55 AM   #1721
Originally Posted by Herk7769 View Post
Just re-did mine and ran into the same issue. That OEM tape held great.
In fact it held so good (and NOTHING up to and including acetone) would remove it. I just stuck the new lights right on top of it.
I work at a large format print shop and run into this tape all the time and have to remove it often. Use a heat gun (very carefully!) never keeping it one spot too long. This should loosen it up enough to pull a lot off.
Whatever won't come off, douse liberally with goo gone or another adhesive remover. Let sit and then scrape off. A plastic squeegee works great, never metal! Whatever residue is left over is removed with isopropyl alcohol.
It's not a quick job, but it works.
warno is offline   Reply With Quote
Old 06-10-2014, 12:46 PM   #1722
Jjs2000z's Avatar
I'm still have trouble figuring out where I can mount my led light strip. I have the 2014 Stealth WA2715. Also can I tie into the electric awning motor?
Name:	ImageUploadedByForest River Forums1402422392.502430.jpg
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 06-10-2014, 12:50 PM   #1723
TURBS's Avatar
Attachment 54882
no you cannot tie into your awning because it switches polarity depending on if the awning is going out or coming in.
TURBS
"Sabre owners united"
Old 06-10-2014, 12:58 PM   #1724
Herk7769's Avatar
Attachment 54882
Unroll the awning and you will see the bottom of the aluminum rail the awning slides into when it is installed. There is room there for TWO strips side by side.
HAM CALLSIGN - KC3FFW
Old 06-10-2014, 01:13 PM   #1725
Jjs2000z's Avatar
Am I mounting the LEDs on the awning roller? Also what am I doing for power?
2014 stealth 2714
Old 06-10-2014, 01:27 PM   #1726
Herk7769's Avatar
Am I? or I am?
I mounted the tape under the awning attachment rail and ran a 4 conductor "telco" (phone) wire from the tape connector down the awning arm that carries power to the awning motor.
I used the same wall penetration to mount the control box right behind the penetration and got power from the "foot light" by the door. That way I can turn the lights on and off using the inside switch.
Others have had success using the outside bug light to mount the controller and a short piece of wire mold to get to the end of the awning tape under the attachment rail.
ID:	54884   Click image for larger version
ID:	54885   Click image for larger version
ID:	54886   Click image for larger version
ID:	54887   Click image for larger version
Old 06-12-2014, 08:54 AM   #1727
I just purchased the supernight led strip light and it did not come with a manual on how to use the remote. I can get most colors but not white. I push the W button on remote but nothing happens. Looked on internet for manual and can't find. Anyone know where to find one?
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 06-12-2014, 09:23 AM   #1728
Herk7769's Avatar
Here is the manual and some other info.
The first image is how to reset the remote.
Name:	Reset Procedure.jpg
ID:	55048   Click image for larger version
Old 06-12-2014, 10:59 AM   #1729
Thank you very much Herk!
Old 06-17-2014, 09:38 AM   #1730
Nick M's Avatar
Wink Great forum!
After beginning with the very first post in this forum and reading upwards of about 800 I skipped to near the end and have decided to add an LED strip to my fiver. My brother-in-law paid $130 at an RV store for a set recently, they look great but way too expensive so I am happy to have found this forum.
Mine are enroute from China and hope to install over the 4th of July weekend. My background is electrical engineering so I don't expect issues finding a fused source of 12v to power the strip. I will end up with both 24 and 44 button remotes so anxious to see how well they work.
Big thanks to the pioneers here that have been so helpful to the faithful followers.
Nick, Sharon and Finnigan
Nick M is offline   Reply With Quote
awning, led pad
