Old 06-30-2014, 06:15 AM   #1741
Wayne & Kim
Wayne & Kimmy's Avatar
My first try at uploading a video failed :-(
Maybe I'll try again after work.
Wayne and Kim
2014 Cedar Creek 36CKTS
2011 Ford F250 King Ranch 4x2 Diesel, added springs
Nights camped: 2014 - 32; 2013 - 23
Wayne & Kimmy is offline   Reply With Quote
Old 06-30-2014, 07:51 AM   #1742
Herk7769's Avatar
File size too big. 500 meg limit.
If you are saving in M4V you need to use a converter like handbrake to convert to MP4.
Name:	Video File Size.JPG
HAM CALLSIGN - KC3FFW
Old 06-30-2014, 10:40 AM   #1743
textman's Avatar
Not sure how that happened! Somehow Wswkmw's video got posted to my post??? Nice work Wswkmw. I am looking at doing the same thing to my CC. Was wondering about the LED channel folks have been using. Going to run mine through the hole the power awning wires go through. Will come out just under the kick step to the left of the dresser. I am then running the wires under the dresser and down through the hole the water lines go into the front basement. Going to tie into the units main 12 volt power bar/ground (where the resettable fuses are). Should be a real clean install when I'm done. Got to order all my parts and pieces. Going to go with the RF controller, but can't decide on which one of those either!
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded w/EGR Delete
Loving Life
textman is offline   Reply With Quote
Old 06-30-2014, 10:46 AM   #1744
Herk7769's Avatar
FYI - I bought the RF controller with the intention of replacing my 44 button one. After "breadboard" hooking it up; I found I liked the 44 button one a little better. Gonna try using the RF one I bought in a friend's installation when he gets his new toyhauler.
Old 06-30-2014, 11:12 AM   #1745
textman's Avatar
Herk, guess the 44 button lets your have more color hues?
Loving Life
Old 06-30-2014, 11:21 AM   #1746
grege's Avatar
I wish you could program multiple colors to change with these. Would be nice at holidays or game time to match your mood or team (ie red, white, blue changing for 4th of July). Anybody find one that does that?
'12 Ford F150 Lariat Super Crew
'17 Grand Design Imagine 2800BH (Previous '13 Roo 21SS)
2016 Nights camped: 7
2015 Nights camped: 21
2014 Nights camped: 18
2013 Nights camped: 26
grege is offline   Reply With Quote
Old 06-30-2014, 12:14 PM   #1747
B D HOWie's Avatar
My solution to awning lights
OK after spending days reading this thread. I would like to know the opinions of the folks who used the channel to mount their LEDs. was looking at this channel
https://www.1000bulbs.com/product/66312/KLUS-B1888ANODL.html
Notice most folks are using the GIP, which seems to be wider. Was wanted to see what others think?
Textman
You may want to look on eBay to see what price you can find. I purchased 4 four foot sections and including shipping paid slightly over $60 shipped from Miami.
Search "led profile". There are many different ones as you probably are aware. I went with the "I" profile because I wanted to angle them at 45 degrees. I used 3M all weather tape and a small screw countersunk every two feet. Filled top of channel with caulking to keep it from holding water.
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 Chevrolet 4500
Using FR app
on 2012 4500 Chevrolet Chassis
Paul
B D HOWie is offline   Reply With Quote
Old 06-30-2014, 01:46 PM   #1748
Herk7769's Avatar
Actually, the RF one has "infinite" colors since you change the colors by sliding your finger around a ring. Then there are "mode" switches.
It is just overly complicated for our needs.
For RGB LED Strip Light Wireless 12 24V RF Touch Panel 9A RGB Remote Control | eBay
Old 06-30-2014, 06:23 PM   #1749
Wayne & Kim
Thanks textman! have no idea how my video ended up on your post! I guess when I mess things up I do it in a big way - considering neither can be viewed!
I didn't do a channel - just put the strips up to that small rail the awning is attached to, used 3m molding tape, seems like it's going to hold up well but only time will tell.
I was going to try to go in thru the awning power wires go in but could not figure where they actually went beyond the exterior wall. I didn't see any kick-plate near the dresser or anywhere else either. I could still go that route if I figure out where things go, but will go down right side to step light otherwise.
Wayne and Kim
Old 06-30-2014, 08:39 PM   #1750
textman's Avatar
Herk, in your attached pics I see in your T connector that you have a male coupler in one end. Did you solder that or will those connector hold those. Also i see your phone cable you used inside the female extension cable, again did you solder that? I am trying to figure out the best way to use the 4 strand rgb extension cable (no finished ends) So I can attach it to the LED strips themselves.
Loving Life
awning, led pad
