Old 07-01-2014, 11:17 PM   #1761
Coming soon to your TV! A new reality TV show: "Pimp my RV".
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 07-02-2014, 05:28 AM   #1762
crunchman12001's Avatar
Originally Posted by jtstromsburg View Post
Are these waterproof for outdoors? I think all LED strips basically are, but just not the controllers!
I did not see where the last link said "waterproof" but same specs as this guy.
This guy is 4 bucks cheaper.
crunchman
2015 F-250 FX4
Old 07-02-2014, 06:36 AM   #1763
Herk7769's Avatar
crunchman
The much cheaper ones I bought said waterproof as well, but I needed to replace both strands after only 2 seasons. THESE are not waterproof; they are BULLETPROOF.
My next time (and there will be one), will be with these.
Herk
HAM CALLSIGN - KC3FFW
Old 07-02-2014, 08:27 AM   #1764
textman's Avatar
Wink More planning...
Going to have extra RGB LED strips left over when I finish pimping my RV
Saw this on another electronics forum:
"You can just connect an RGB strip straight to a 12V power supply to produce a fixed colour running full brightness.
Connect the V+ wire (this will be either white or black) to power supply positive. Then connect 1 2 or 3 of the RGB wires to power supply negative to produce red green blue cyan magenta yellow or white.
A 1.5m strip of 30/m 5050 RGB strip will need around 0.8A if all LED's are ON = white."
Sounds like I can make one constant color from these RGB too, by hooking them straight into my 12 volt on the RV. Now I won't have to buy extra single color lights for the steps. DW wants them hooked to the switch like others have done. Now when she changes her mind that she don't like blue, I can play with the wiring configuration and get the constant color she wants!
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded w/EGR Delete
Loving Life
textman is offline   Reply With Quote
Old 07-02-2014, 09:07 PM   #1765
Wayne & Kim
Wayne & Kimmy's Avatar
Keep the updates coming, Textman! I leave in the morning for weekend trip and will try mine out at nite for the first time, so I'm excited! I will do the 12 volt thing in time, and am steadily picking others brains here for ideas on all aspects of this project, so u too are now being watched! I can't wait to see how urs turn out!
Herk, so r u going to go with the Dream Magic series next time? I was looking at the array of color options they offer but could not tell if you can custom program a series of colors to run, say like red to white to blue . Being a vet and quite resourceful as u r, I'm sure that you will figure it out and get us all pumped up to join that bandwagon!
Wayne and Kim
2014 Cedar Creek 36CKTS
2011 Ford F250 King Ranch 4x2 Diesel, added springs
Nights camped: 2014 - 32; 2013 - 23
Wayne & Kimmy is offline   Reply With Quote
Old 07-03-2014, 09:01 AM   #1766
textman's Avatar
Talking
Now the pressure is on!
Was talking to my son last night about the LEDs and we decided with some of the extra strips we could pimp the truck too... I told him if the wiring scenario works we can run them to the extra switches on the F350 and in theory be able to switch off and on the different color lights!
Loving Life
Old 07-03-2014, 12:22 PM   #1767
If you buy enough of these things and hook them up top a computer you can mount them in strips on the side of your RV and make moving images like the Goodyear blimp.
- 2000 Coleman Mesa
Old 07-08-2014, 02:05 PM   #1768
Gregg Willow's Avatar
I finally installed my awning LED strip and turned out pretty well. I had initially installed the LED strip under the awning mount and thought it was a perfect fit until I turned them on during a test. I do not have the smooth fiberglass walls and the aluminum seemed to deflect the light. I then installed on the wall just under the awning mount and that was much better.
I used the weather-proof 5050 RGB and bought a quick-connect 4-pin cable to go from the LED strip to the porch light. My original porch light was incandescent and did not have a on/off switch at the fixture. So I bought an LED porch light that had the on/off switch. Since the power is coming from the porch light I wanted to control which light(s) were on. I drilled a hole on the bottom of the light just big enough for the 4-pin cable. I then wrapped the cable and LED ends with electrical tape to keep the connection dry. If the LED strip needs to be replaced it will be simple to do so.
ID:	57603Click image for larger version
ID:	57606Click image for larger version
I also decided to go with the wi-fi controller. I did not want to have another remote so I downloaded the Magic Color app to my iPhone. Its pretty cool to change color by dragging your finger around on the display. It also has a bunch of preset modes for changing colors and can respond to the music on my iPhone. I mounted the wi-fi controller in the closet behind the porch light with a Command strip. I drilled a hole through the wall behind the porch light and pushed through the LED 4-pin cable and power/ground wires to the controller.
ID:	57608Click image for larger version
And a pic of the lights with no flash from my iPhone. This was a fun project! Thanks for all of the great ideas and information on this thread.
2016 Ford F-150 4x4 Supercab XLT EcoBoost
2012 Salem Cruise Lite 221RBXL, Andersen No Sway WDH, (2) Honda EU2000i's
Gregg Willow is offline   Reply With Quote
Old 07-08-2014, 05:02 PM   #1769
cstover's Avatar
Nope. Not waterproof. Guess I will use these for something else. Time to buy a new one. DW is thrilled.
cstover is offline   Reply With Quote
Old 07-08-2014, 09:30 PM   #1770
Wayne & Kim
Originally Posted by Herk7769 View Post
Shame your step light is on the other side of the steps; as that is how I re-wired mine. (I pulled the plastic "bucket" out of the front storage area and ran the wire to it). Originally, I ran it to the basement light, but it was inconvenient to have to leave the camper to shut off the awning lights when we went to bed.
Another option is to use the existing bug light and a wire mold (or inside the wall if you can) to run the control wires up to the awning track. Use a T connector to attach the power wires to the middle of the LED track.
Hi Herk, I will be looking at the 12v wiring soon. I see on the pic you provided before that if I cut the wire that would plug into the AC transformer I will likely have red and black wires. The small step light to left of steps has wiring accessible behind the fender area which are connected with twist-on wire connectors so I should be able to tie right in there. Just wondering which wire will go to which. I didn't take a photo yet, but can if that will help. I seem to recall wires being black and white. I apologize if I sound obtuse.
Wayne
Wayne and Kim
awning, led pad
