Old 04-14-2015, 10:04 AM   #1871
Also just found this wall mounted control for anyone else like me that doesn't want another remote. This is for the rgbw lights
http://www.amazon.com/SUPERNIGHT-Wal...1WGNBCTP0YFE52
New to us
2012 Sierra 365SAQ (kids go play in your room) pulled with an 2011 GMC Sierra
Previous Campers;
2008 Wildcat 32QBBS(your pregnant again), 2004 Wildcat 29BHBP (oooh twins), 2000 Travel Supreme (pre kids)
Dirt_Farmer is offline   Reply With Quote
Old 04-14-2015, 11:01 AM   #1872
I have looked at these lights so much my head is spinning. I am looking for plain white, or warm white waterproof lights. No dimming, no fancy colors. I just want to replace the ones that are crap and not working properly on my roo23Ikss, that are hardwired into the wall switch. Which ones do I buy?
2014 Rockwood Roo 23IKSS
2012 Dodge Ram 1500 Hemi 4X4
Me, Hubby and Luna the Lab
sewingcybermom is offline   Reply With Quote
Old 04-14-2015, 07:20 PM   #1873
I put a set on the 5 er last summer.Bought some 3m double sided tape and everything worked great.UNTIL it hit over 100 for a few days.When I went out to the camper all the lights had let go and fell to the ground.Haven't got around to messing with them this year.Now I'm thinking I need to get the back up.What the heck can I use to keep them up?I'm going to go to a body trim shop and see what they have.Any other suggestions would be appreciated.
DaveandSue is online now   Reply With Quote
Old 04-15-2015, 03:25 AM   #1874
crunchman12001's Avatar
DaveandSue,
I used this 3M tape 2 years ago, still holding strong. You have to prep the area with rubbing alcohol before applying the tape.
Good luck,
crunchman
2015 F-250 FX4
Old 04-15-2015, 06:23 AM   #1875
The tape I used stayed up.the lights fell off.
Old 04-17-2015, 09:14 AM   #1876
Just received my lights and they don't work properly. When I hit the W button on the remote they get stuck in flashing mode and the receiver does not respond to the remote.
Also they appear do just have RGB leds even though the instruction sheet says they should have Static White. Here is a link to what I bought:
3528 RGB 300LED SMD 5M 500CM Light Strip Waterproof 44Key IR 12V 2A Power Supply | eBay
FR Stealth 2313
Chevy 2500HD Duramax
hammick is offline   Reply With Quote
Old 04-17-2015, 09:26 AM   #1877
Originally Posted by hammick View Post
Just received my lights and they don't work properly. When I hit the W button on the remote they get stuck in flashing mode and the received does not respond to the remote.
If you just want white, bypass the control box and hook up 12v to the power lead and ground red,green and blue wires
Hornnumb2 is offline   Reply With Quote
Old 04-17-2015, 09:30 AM   #1878
TURBS's Avatar
I don't see in the listing where it says white.
Rgb is red blue and green
All the lights together make a "white"
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-17-2015, 09:52 AM   #1879
Thanks but I was able to get them into RGB all on solid and that certainly isn't white. My controller is very quirky. If they get stuck in flashing I have to disconnect the leds from the receiver and then use the remote to change mode with the leds disconnected.
I do have a set of white leds from China. I will probably try to hook those to this receiver.
FR Stealth 2313
Old 04-17-2015, 10:31 AM   #1880
Either my receiver or my remote is whacked. No rhyme or reason on which button will put them into a quick RGB flash mode. Once this happens the light need to be disconnected and then a different mode selected with remote. Reconnect and then lights will be in that mode. The W and all buttons below W seem to consistently send them into a tizzy.
Even if the seller is willing to send a new receiver it will take a month.
Oh well at least they were only $14.
Neat idea if they worked.
FR Stealth 2313
awning, led pad
