Old 07-18-2015, 10:35 PM   #1921
paro4life's Avatar
Originally Posted by bagged123 View Post
I just ordered the LED string from Amazon, and they have no tape, adhesive to hang them with to my TT. What are you guys using to attach the string, etc. to your TT? I can only find dbl sided tape by scotch and it won't stick to the casing of the lights.
any thoughts or suggestions on what to use
I installed mine directly under the awning on the trailer for protection. I didn't think the factory tape was strong enough so used 1" 3M dbl sided tape and cut in half which is the same width as the light strip. Works great. Been almost a year no problem. I bought another light strip recently for inside and I peeled the entire ddl sided tape off thinking it was the film. Ruined it. The light strip tape is very thin and cheap quality.Had to get the 3M dbl sided tape.
paro4life is offline   Reply With Quote
Old 07-19-2015, 10:28 AM   #1922
LED Awning Lights Installation Mini Lite 2503S
I read this entire thread to get ideas on how to install my lights and how I wanted them to function. Lots of great ideas. I boiled them down to what would work for me and my Mini Lite 2503S and thought that I should share my results. My installation had to meet certain criteria. First the lights needed to work if my awning is stored or deployed. Second I did not want to have to connect or disconnect them each time I used them and third they had to run on 12VDC so that I could use them when I boondock. Since I wanted the lights to work no matter if my awning was rolled up or extended then I had to install them underneath the rail that the awning is attached to. If I installed them on the camper wall then most of the light would shine on the awning when it is rolled up. I installed them using the factory adhesive and so far they are still attached. I used a tie wrap mount on each end to help keep the ends from coming detached.
[IMG][/IMG]
Make sure that the wire goes up and over the channel so that it does not get sheared when the awing retracts.
[IMG][/IMG]
Ran the 4 conductor wire down the same track that the awning power wires use and followed them using the same hole into the storage compartment. Couldn't find a clean way to get 12V power so I just ran my 12V wire back out the same hole, down the side of the camper and underneath. I attached this wire directly to the terminal block where the battery wires connect to the circuit breaker. Used tie wrap mounts to hold the wire in place. If they start to come off I will drill holes and use pop rivets.
[IMG][/IMG]
[IMG][/IMG]
I used this wifi controller to control my lights.
Amazon.com: Cooligg Wifi Wireless RGB LED Strip Controller for iOS iPhone iPad Android Smartphone Tablet: Home Improvement
I have an app on my iPhone that I use to control the wifi controller. It does not have as many functions as the infrared remote but it has enough for me.
Looks like I need to straighten the controller but I cannot see it when the door is closed
Daytime awning deployed
Daytime awning rolled up
You would think that when they installed the porch light that they would have tried to center it over the window. I laugh every time I look at it.
Plenty of light at night.
2013 Rockwood Mini Lite 2503S
2005 Jeep Grand Cherokee Limited 4.7 L
Equalizer 10,000# Hitch
sjones61 is offline   Reply With Quote
Old 07-22-2015, 06:54 AM   #1923
Summer2Go
Summer2Go's Avatar
If you wire it into the camper lights that already work on your battery, then you have lights when you are boon docking?
Summer2Go is offline   Reply With Quote
Old 07-22-2015, 07:11 AM   #1924
Wayne & Kim
Wayne & Kimmy's Avatar
Yes indeed - the lights work great off of a 12 volt power source.
Wayne and Kim
2014 Cedar Creek 36CKTS
2011 Ford F250 King Ranch 4x2 Diesel, added springs
Nights camped: 2014 - 32; 2013 - 23
Wayne & Kimmy is offline   Reply With Quote
Old 07-22-2015, 07:14 AM   #1925
Wayne & Kim
Good job sjones61! The lights look great, and your post was very instructional and informative with the visual aids along the way.
Wayne and Kim
Old 07-22-2015, 12:33 PM   #1926
Summer2Go
Summer2Go's Avatar
I have my lights plugging into the outside electrical outlet for now. Is there an easy way to get them to connect to the battery from the underside of the trailer? I don't want to drill holes in anything, and most times we will use them at a campground with electricity.
Old 07-22-2015, 12:40 PM   #1927
Summer2Go
Summer2Go's Avatar
I am not very knowledgable about electricity, batteries, and such, but sjones61 do you have a picture of the 'terminal block' where you connected to the battery?
Old 07-22-2015, 01:23 PM   #1928
I don't have a photograph of mine but it is actually an inline circuit breaker. I connected the ground of my 12VDC wire to the negative terminal of the battery and the positive wire to the downstream side (side that the battery cable is NOT attached to) of the circuit breaker. Not sure of your setup but if you follow your positive battery cable under the camper you may find something like this.
I have an inline fuse to install between the circuit breaker and the controller I just have not done it yet.
Old 07-22-2015, 03:36 PM   #1929
Wayne & Kim
I was able to tie mine in to the step light wiring under the trailer. Thus I am able to turn on the porch and step lights and the LED awning lights come on also. Similar to you, I had some left over and used a Y adapter, but put my excess behind my steps.
Wayne and Kim
Old 07-27-2015, 06:32 PM   #1930
Hi:
A couple of quick questions on installing the LED awning light strips:
1. I plan on installing the white LED control box inside a waterproof electrical junction box to keep it and the LED connections out of the elements. Would this create an overheating problem for the box's electronics?
2. I plan on running a wire from that junction box through the TT outside wall to tie into an existing 12v feed for the table light. The distance is approx. 6 feet. From what I can research, the suggestion is to use 14 gauge wire. I was hoping to use 16 gauge because it is smaller and neater to run but I don't want to create an unsafe situation. What size wire have you used for your 12 volt power source?
Appreciate any info / suggestions!!!!
Ontherock is offline   Reply With Quote
awning, led pad
