Old 09-21-2015, 02:39 PM   #1961
Originally Posted by kdp3078 View Post
Sorry, I should have explained better. Wiring in to the light I don't have a problem, it is getting some type of extension, or splicing in the middle of the strip, so I can go straight down from the LED Strip in to the light housing.
I don't want to have to run the strip all the way down, and then run an extension back 8 feet to go in to the housing if there is a better way.
I see what your saying.. I thought about doing it that way but decided to run the 12 volts inside the camper in the cabinet and mounted the controller in the cabinet .. then ran the jumper from the lights inside to the controller.. From the outside all you see is the small wire on one end going in to the controller..
Joe
meganjoe is offline   Reply With Quote
Old 04-04-2018, 11:06 PM   #1962
gmann55's Avatar
Hate to sound dumb, but where do you mount the eye so you can change the lite mode from out side! The eye has only a 6 in lead from the controller?
gmann55 is offline   Reply With Quote
Old 04-05-2018, 04:11 AM   #1963
crunchman12001's Avatar
I went through the hole where the wire came in for the electric awning. I mounted the controller inside and ran the IR eye through the hole to outside. Others used the porch light ect.
It will take you awhile but if you read this entire thread you will see many ways to mount the lights and get power to them.
2015 F-250 FX4
Old 04-05-2018, 06:03 AM   #1964
Agree with Crunchman,but I think after the "Novelty" wears off the controller key pad will be inside the unit in a drawer! Most find what they like and leave it set there! Youroo!!
Old 04-05-2018, 04:58 PM   #1965
Agreed, I leave mine set on Blue.
2015 F-250 FX4
Old 04-09-2018, 10:29 PM   #1966
KMP44's Avatar
Just drop $6.95 on an RF controller upgrade like this one and you are good to go. No drilling or line of sight required...
https://www.ebay.com/itm/2-4GHZ-RGB-...ss!61354!US!-1
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 04-15-2018, 07:04 PM   #1967
larry2c's Avatar
I've not read all 200 pages of this thread but I have gone through quite a few and haven't seen this question answered. We have a '17 Cruise Lite and the awning light seems to be simply a white light strip with on & off (no LED remote was provided or found). Is there anything that might indicate that this light could be multi color? I'm hoping maybe I could change it to blue or green and not have it so bright.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
Old 04-15-2018, 07:16 PM   #1968
RandK-M's Avatar
Most of the factory ones are just one color, white. At least that's what they put on my 2017 2109s.
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
RandK-M is offline   Reply With Quote
Old 04-15-2018, 07:18 PM   #1969
larry2c's Avatar
Ray
That's sort of what I figured but I was hoping for other options.
Could I buy a multi color set and just replace the current lights? Seems like that would be simple since the wires are already routed...
'11 F150 5.0
Two shedding mutts
Old 04-15-2018, 07:45 PM   #1970
rsdata's Avatar
Lots of options for multi-color with remote...
you will find options from $5 to $150...
they are basically all the same...
start here...
https://www.amazon.com/RoLightic-SMD...VTNK5SPCYCWJ8B
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
awning, led pad
