Old 06-18-2012, 03:50 PM   #331
Herk7769's Avatar
Originally Posted by Ft W crew View Post
Amazon.com: Ledwholesalers IP67 Waterproof 16.4 Ft RGB Color Changing Kit with LED Flexible Strip, 44 Button Controller + Remote and 12 Volt Power Supply, 2038kit: Home Improvement
After reading 33 pages I too decided to pull the trigger (or in this case push the enter button). After reading the description carefully it appears to be the same lights as Herk, just quicker shipping time and $10 more. It appears I will have these lights installed faster than what it took me to read all these pages. Looking forward to 4th of July camping trip with my fancy lights.
Has anyone programed it to flash Red, White and Blue yet?
Those are not the ones I bought. I got the brighter 5050 LEDs (not 2038s) and a rubberized waterproof strand. Those seem waterproof as well, but my strand has a rubber cover.
http://www.ebay.com/itm/270939580723...fsrc=1&afsrc=1
HAM CALLSIGN - KC3FFW
Old 06-18-2012, 04:17 PM   #332
TURBS's Avatar
No ! but that would be fitting!
Old 06-18-2012, 06:33 PM   #333
toniundpetra's Avatar
Now I had to get some Led's too. I'll put them in clear shrink tube sock. That will keep the moisture out when it is rolled up and stored. I'll run a 12v from the battery with fuse block to the transformer. Run the wire extended up to the awning motor connection through the tube. Put a easy off quick disconnect on the moving side. It will disconnect if the love of my life pulls the awning without disconnecting.
KIS that is the motto.
toniundpetra is offline   Reply With Quote
Old 06-18-2012, 07:18 PM   #334
cootr68's Avatar
I ordered white led solar/battery powered waterproof 20 ft. Going to mount them on the frame rail. When traveling I will put the solar charger in the back of the truck and when set up put it on the a- frame. Hope it works. http://www.ebay.com/itm/Lighting-Ess...-/280901744051
1997 Sierra m-27fls tt
1999 Pontiac T/A
2006 flstn Deluxe
2004 Polaris 330 magnum
Bear the Labrador
cootr68 is offline   Reply With Quote
Old 06-18-2012, 07:37 PM   #335
Originally Posted by cootr68
I ordered white led solar/battery powered waterproof 20 ft. Going to mount them on the frame rail. When traveling I will put the solar charger in the back of the truck and when set up put it on the a- frame. Hope it works. www.ebay.com/itm/Lighting-Essentials-Solar-LED-Rope-Lights-20ft-Long-/280901744051
I think you will not have enough light from the Led lights. Everybody buys 60 LED per meter. Hope it works.
Old 06-18-2012, 07:43 PM   #336
cootr68's Avatar
Just a soft glow will be fine. If they don't work out I can put them under the top rail on the deck at home.
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
Old 06-18-2012, 08:18 PM   #337
Herk7769's Avatar
Did you folks see this?
Music Audio Sound Driver RGB x3 Strip Light LED Controller 12V 60W IR Remote | eBay
Difference between the waterproof code IP65 and IP67? Anyone?
The two similar white ones are IP65 and the copper colored one is the IP67.
ID:	15428   Click image for larger version
Old 06-18-2012, 08:29 PM   #338
Rsgtivr6's Avatar
Not really sure if I would do the music control myself. Just want a nice ambient light when sitting around the campfire at night. When I was in high school, I would have been more apt to toss this under the car and hook it up that way, but I don't have a set of 12's with a 1000 watt amp in the trailer nor do I plan on thumpin the bass at a CG anytime soon, lol. Maybe for tailgaters this would be pretty cool.
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 06-18-2012, 08:38 PM   #339
Coops1's Avatar
In enclosures IP54 is splash proof, IP56 is for direct water spray so maybe 67 is underwater?
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 06-18-2012, 08:55 PM   #340
Check out:
http://en.m.wikipedia.org/wiki/IP_Code#section_1
awning, led pad
