Old 06-21-2012, 12:46 AM   #351
my led installed under the awning on the wall. hooked into the front spot light so that switch turns them on and we can still use the porch light Amber for late night. really does a great job lighting the whole area.
ammdrew is offline   Reply With Quote
Old 06-22-2012, 11:20 AM   #352
Originally Posted by Cincy6 View Post
For those interested in getting them faster (I wanted them by Memorial day weekend), I ordered these:
Waterproof 150 Color Changing SMD5050 LED Lighting Strip Kit RGB 16.4ft, 2038kit
Amazon.com: Waterproof 150 Color Changing SMD5050 LED Lighting Strip Kit RGB 16.4ft, 2038kit: Home Improvement
on Amazon on Saturday and received today (Monday) using Amazon Prime 2 day shipping free trial. Total cost was 39.00 including AC adaptor. Paid a little more but received them much faster.
I'm thinking about getting these as I have an Amazon Prime account. These are waterproof, has the 12V power supply and already has the 44 button controller. However what does the 2038 kit mean? Are these not 5050 LED's?
cdbus is offline   Reply With Quote
Old 06-22-2012, 11:40 AM   #353
I think that is just the order number, but not sure. Yes, they are 5050 LED's and came with everything shown on the link. The 3M tape has held and they have worked great since Memorial day. The remote is a little weak though, range is only about 10 feet and you need to aim right at the receiver for it to work, but overall they are great and get alot of comments!
2012 Roo19
2003 Trailblazer EXT V8
2013 Ford Super Crew F-150 EXT
Cincy6 is offline   Reply With Quote
Old 06-22-2012, 11:48 AM   #354
I think the numbers represent the brightness of the LED. The 5050 being brighter than the 2038. I could be wrong, it's happened before.
Len & Cheri is offline   Reply With Quote
Old 06-22-2012, 12:20 PM   #355
Originally Posted by sdagro View Post
Yea. I have some time restraints tho. They are only 45 miles or so from me. Plus it has a plug & play mode?? Blinks to music. Thought that might be good during tailgating. We will see. Steve
I got mine in on Wednesday and had my daughter hold them against the camper below the awning track that night to see the effect. Bringing them back to P.O. today. With my full body dark paint job and black w/2 shades of grey awning, even the brightest white doesn't give me much more than a highlight. And for $42 I was expecting a little more. Seems like they would work a lot better on a white or more reflective color on both camper and awning. I am sure I can find something else to blow that $40 on. Steve
sdagro is offline   Reply With Quote
Old 06-25-2012, 12:14 PM   #356
Okay, I have to ask. What are you all using to affix your lights to your camper? I bought some car moulding tape from the auto store thinking, if it can keep a piece of molding on a car, then it surely will be able to keep my lights on my camper. The problem is that I can't get it, or anything else for that matter, to attach to the plastic casing of the LED light string. The stuff sticks great to the camper, but the lights fall right off of the tape...and that is with it just sitting there! I can't imagine trying to drive down the road and them stay on!!
Anyway, any suggestions on what tape, or other method, you all use to attach your lights would be greatly appreciated. I'm going to try to take some sandpaper and rough up the backside of the light sleeve and see if that will make it adhere better.
Larry
2004 Toyota Tundra Double Cab
2010 Rockwood 2701SS
Killman is offline   Reply With Quote
Old 06-25-2012, 12:19 PM   #357
Herk7769's Avatar
The ones I got came with 3M double sided tape already on it. Just peeled off the covering and stuck it right onto the camper.
2 trips and nothing budged. (In fact I was less than even when I put the first strip on and when I tried to move it up a little bit to fit the second string it was on solid and unmovable.)
I would need a heat gun to move it; I think.
HAM CALLSIGN - KC3FFW
Old 06-25-2012, 05:24 PM   #358
TURBS's Avatar
Not sure what ones you bought but I got the ones the op got from ebay and they are brighter than I expected.
Even dimmed on the lowest setting there still pretty bright.
Old 06-25-2012, 06:36 PM   #359
Used the outdoor 2 sided tape from Lowes. Mine came with the 3m tape already installed and fell off after about 4 days. Luckily we hadn't gone anywhere. Bought the outdoor tape, split it on my band saw and used it. It's been on for a month and we've towed in rain and it has rained for 2 days and 2 nights here in FL and they are still stuck tight. Highly recommend the outside tape.
Old 06-25-2012, 07:09 PM   #360
punkaccountant's Avatar
I'm thinking about getting a strand of these lights to install under the awning directly on my TT and was wondering if these get hot like the 5050 paddle lights that install in your light fixtures? Those can get pretty hot. If so, 1) will this eventually affect the sticky tape and 2) will that heat hurt the gelcoat or sides of the TT?
punkaccountant is offline   Reply With Quote
awning, led pad
