Old 05-13-2012, 06:49 PM   #31
Herk7769's Avatar
Not dark Yet.
I had many more photos of the install, but my Thumb drive fried my chip and dumped the photos again. I also lost the wedding photos of my friend's son's wedding. Bummer.
My plan is to weatherproof the box; right now I have it Velcro'ed to the wall and I remove it for travel. I am thinking a covering of Eternabond might just do the trick. It is white; waterproof; and will blend in better.
ID:	13733   Click image for larger version
ID:	13734   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 05-13-2012, 07:20 PM   #32
Originally Posted by herk7769 View Post
... I am thinking a covering of Eternabond might just do the trick...
Now you need to hook it to 12v and remote control it.
Old 05-13-2012, 07:21 PM   #33
TURBS's Avatar
looks good cant wait till it gets dark !
Old 05-13-2012, 07:22 PM   #34
TURBS's Avatar
It has a remote does it not ?
The one I ordered did !
Old 05-13-2012, 07:22 PM   #35
Herk7769's Avatar
It is hooked up hardwired and HAS a remote control.
Now to figure out how to post a video.
Old 05-13-2012, 07:26 PM   #36
TURBS's Avatar
I like to load mine to you tube . Is there another way ?
Old 05-13-2012, 07:31 PM   #37
Herk7769's Avatar
No idea, as I have never done it before.
May have to make a clip of cycling through the 16 colors and post it.
16.4FT IP65 5050 SMD RGB 5M Waterproof 300 LED Strip Lights +24 Key IR Remote | eBay
Old 05-13-2012, 07:32 PM   #38
Could the box be put inside and not worry about waterproofing it?
Old 05-13-2012, 07:47 PM   #39
Herk7769's Avatar
Maybe.
I might be able to re-do it now that I have had time to think about it.
If I had to do it over (and I may still as it would not be a big deal), I would run 4 wire (like they use in hardwired smoke detectors - I have a spool of it) from the basement (where the awning remote stuff is located) to the LED strip. The only real problem with putting it inside is the remote is IR and hard wired to the control box. (see picture)
The little pigtail with the IR sensor is pretty short.
Old 05-13-2012, 07:57 PM   #40
Happy Campers 79's Avatar
I couldn't resist! Just ordered a set. Thanks!
Mike & Kristin
2013 Surveyor SP220
2008 Mountaineer
Happy Campers 79 is offline   Reply With Quote
awning, led pad
