Old 08-01-2012, 06:48 AM   #471
TURBS's Avatar
Originally Posted by BriBoy01
Does this one also include the 110v plug?
I would say no but I'd email the seller for sure !
Old 08-01-2012, 07:03 AM   #472
Md Jeff's Avatar
Originally Posted by tomblakeney View Post
I ordered mine over 30 days ago from ebay from china and after 3 emails back and forth they are going to re ship mine. First not good ebay experience. Darn I really want to try these
Don't say that, I ordered these on the 21st (16.4FT IP65 5050 SMD RGB 5M Waterproof 300 LED Strip Lights +24 Key IR Remote | eBay) and I am still anxiously waiting on delivery.....may be the same vendor as yours
Md Jeff is offline   Reply With Quote
Old 08-01-2012, 07:08 AM   #473
Md Jeff's Avatar
Originally Posted by CRZ View Post
Mine has the tape, same kind as Lou. I left the tape backing on mine and pushed it into the awing channel just to try it and never pulled it out yet. I installed it without a problem.
Rolling the awning up hasn't had any Ill effects? I would like mine on the the roller as well but figured it wouldn't stick to the awning base as it isn't smooth
Old 08-01-2012, 07:34 AM   #474
TURBS's Avatar
Not on the roller but in.
Old 08-01-2012, 07:37 AM   #475
tomblakeney's Avatar
Diff vendor Jeff but same delivery...lol
Tom Blakeney/Gena Horne
Saint John New Brunswick
Canada
Total nights camped in 2013: 38
tomblakeney is offline   Reply With Quote
Old 08-01-2012, 09:22 AM   #476
Mickeetwo's Avatar
Tried my new LED lights on my 8 day trip last week and they seemed to hold up fine. Mine came with the 3m tape on the back of them so I just taped it to the roller tube right above the channel. Was going to insert them into the channel but the lights got in the way of my awning pull strap. Had several days of torrential downpours and drove in a lot of rain and they did just fine. I rolled them up with the awning and they worked each time I put the awning out. I also put some of the clear LED's under the front of the RV by the propane tanks, by each of my steps and on the back. Have a seperate switch for the steps and the front and back. I used Marine grade switchs that had red LED tips on the switch so you can tell when they are on. Mounted the switches in the front of the RV.
2006 Flagstaff 831RLSS
2008 Tahoe LTZ
1999 Siverado
Mickeetwo is offline   Reply With Quote
Old 08-01-2012, 09:24 AM   #477
looks good... i need some step lights too......
Canada
Old 08-01-2012, 09:28 AM   #478
Mickeetwo's Avatar
The LED's are real easy to work with. I bought a 16' roll of the waterproof clear LED's for about $12.00 You can cut these every 3 inches if needed. After cutting all you have to do is solder a positive and negative wire to them and they run on 12v. Super easy to do and work with.
2008 Tahoe LTZ
1999 Siverado
Old 08-01-2012, 01:22 PM   #479
cmptrkd's Avatar
I wanted to mention for everyone. If you search in Ebay for "waterproof led 5050 rgb" and sort by distance, you should be able to find a few USA sellers. I did, yes, I paid more then the 22.00, but less then Amazon, I think I paid 27.00, they came from Chicago in about 3 days, they have the 3m tape on back, and are look identical to the other lights. they did NOT come with the 110 adapter, they did come with the controller and remote, but I think most of us are wiring these into the 12Volt system on the camper, so who cares. The same seller did have a 110 adapter for a few more $$. Radio shack could also hook someone up with an adapter, though not sure what the cost would be.
I was happy to pay the additional 5.00. I called it expedited shipping.
Highlight 5M 5050 SMD RGB LED Strip 300 LEDs Waterproof DC12V + 24Key IR Remote | eBay
cmptrkd is offline   Reply With Quote
Old 08-01-2012, 08:24 PM   #480
Finally arrived
After reading all the posts and all the hype on these lights mine finally arrived. I ordered mine from Amazon and my first concern is it says they are not waterproof. Now-I am totally confused as to how you mount the remote sensor and the converter. Where do you put all this stuff!!?? I have a Rockwood Roo 19 w/13' awning. Right now I have boxed everything up and am contemplating sending everything back. If anyone can give me some input/pictures as to how to do this I would appreciate it. Also, I can't even figure out all the buttons on the remote. I'm beginning to think that the white Xmas lights for 3.99 at the Xmas Tree Shop are a GREAT deal! Please Help!
dec1952 is offline   Reply With Quote
awning, led pad
