Old 09-06-2012, 03:12 PM   #621
Originally Posted by f1100turbo View Post
And some of us work smarter and not harder !
But you have to unroll the awning and plug them in.
Old 09-06-2012, 03:12 PM   #622
Originally Posted by herk7769
THAT will get ya banned
Don't worry, I wouldn't want heads to explode in the retirement village. . Anyone interested in LED boobies can PM me.
crasher is offline   Reply With Quote
Old 09-06-2012, 03:42 PM   #623
TURBS's Avatar
Giggle
Old 09-06-2012, 05:35 PM   #624
Cmmjmoore's Avatar
Boy the last few remarks were very helpful, I always wondered how someone could have 1000+ post on a helpful sharing website like this and now I guess I know.
2013 SP 240 Anniversary
Tundra CrewMax 5.7L in Pyrite Mica
Clark, Mary Jane & Max our German Short-haired Pointer
(2011-42)
Cmmjmoore is offline   Reply With Quote
Old 09-06-2012, 06:08 PM   #625
Originally Posted by Cmmjmoore View Post
I have only used the camper twice since we received it and have never had an electric awning before so I wasn't sure you could just reach up and pull it down. I am not nearly as sophisticated as many of you here and so I looked for a simpler method.
I thought I would split the 12 volt circuit that is for the light in the pass through and put in a female DC auto plug (cigarette lighter as we use to call them) mounted to the wall up high out of the way. Then I would Velcro the control box in the awning channel up where it plugs to the strip, then run a line down the awning channel with Velcro attachments points with a male DC plug on that end. Then I could open the pass through plug in the lights and be ready to go. Admittedly it will require unplugging the unit to role up the awning but gosh into everyone life a little rain must fall. Am I missing something with the this country boy method.
You can't just tug on your electric awning on your Surveyor, as the arms will probably bend. Look along the outer edge and you will see a bunch of holes and a silver button poking out of one of them. This is the adjustment I was talking about. simply push in the button and pull the arm down until it clicks into one of the holes that puts it at the level you want. The nice thing about this awning is it will hold in that position while you attach your gizmos as you describe. Then return the awning to full elevation by reversing the process.
Old 09-06-2012, 10:55 PM   #626
Cmmjmoore's Avatar
Appreciate the advise
(2011-42)
Old 09-07-2012, 07:13 AM   #627
wrp
Really very impressed with all of the clever ways these diode lights have been wired in. Couple of questions I have and I have read through all 61 pages. It seems like what ever way you wire this up you still have to get out a ladder to plug the strip in and the head of the roller, is that a correct assumption? Obviously that is not for the guys who have installed them under the awning but out on the roller.
I installed mine on the roller so they can be used with the awning cantilevered off the camper or the carport way...without plugging anything in.The excess wire rolls up with the awning.When the awnings rolled out (not in the carport way)I just tuck the wire into the channel of the rail....when in carport position the excess wire is used up to travel along the ground under the carpet.
The wire runs down the arm under the camper to a junction with a waterproof toggle switch so I can shut off the lights going to the awning when its rolled up and still have them on behind the steps and around the top of the door. Wires enter through the outside 110 outlet which is about a foot away from the rail/arm mount....that's also where I put the eye for the remote.The wall wart and controller are inside the camper under the seat storage area right next to the 110volt outlet and put a little wood box/shield with a hinged cover for easy access around it so I don't have to worry about anything resting on it of bumping it.
wrp is offline   Reply With Quote
Old 11-03-2012, 11:19 AM   #628
Av8orLou's Avatar
Just wanted show the lights I just installed
ID:	21337   Click image for larger version
ID:	21338   Click image for larger version
2015 GMC Denali HD Z71 4X4 - D/A
2004.5 Chevy D/A
2013 Cedar Creek 34rlsa
2003 Four Winns Funship 214 Deckboat - Hawaiian Breeze
Av8orLou is offline   Reply With Quote
Old 11-03-2012, 11:22 AM   #629
Herk7769's Avatar
Looks great.
HAM CALLSIGN - KC3FFW
Old 11-03-2012, 11:29 AM   #630
Originally Posted by herk7769 View Post
Looks great.
X2
awning, led pad
