Old 01-26-2013, 12:57 PM   #641
TURBS's Avatar
I think herk7769 had the best mounting option.
Turbs
Old 01-26-2013, 01:35 PM   #642
Herk7769's Avatar
Turbs
If you are careful to place the strip along the edge, there is enough room for two strips of LED lights in the mounting rib against the camper wall. I need to get a photo of the double strip mod.
ID:	23480   Click image for larger version
ID:	23481   Click image for larger version
ID:	23482   Click image for larger version
ID:	23483   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 01-26-2013, 06:46 PM   #643
Owner/Operator
RodeoGeorge's Avatar
After just reading through all 642 posts, I went looking for a source. Using Herk's link, I then scrolled through the 16 pages of Star-doo listings and found the 5 Meter, 300 LED, 5050 Waterproof SMD LEDs with the 44 Key Controller for $25.27.
5M 300 LED 5050 Waterproof RGB SMD Flexible Lamp Strip Light 44 Key IR Remote | eBay
Herk, do these look like the ones that you used, WITH the 44 Key Controller?
Thought I'd check to see if I missed something.
RodeoGeorge
RodeoGeorge is offline   Reply With Quote
Old 01-26-2013, 06:48 PM   #644
TURBS's Avatar
Bad link ↑↑↑↑↑↑↑
Old 01-26-2013, 06:56 PM   #645
Owner/Operator
Sorry about the link. Forgot that I copied something else after the link. I corrected the post, and also here's the link.
RodeoGeorge
Old 01-26-2013, 06:59 PM   #646
Coops1's Avatar
Bad link ↑↑↑↑↑↑↑
It works for me
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 01-26-2013, 07:08 PM   #647
TURBS's Avatar
RodeoGeorge
Works now!
Old 01-26-2013, 07:13 PM   #648
Herk7769's Avatar
I used the smaller controller initially and added the larger controller later.
16 4ft IP65 5050 SMD RGB 5M Waterproof 300 LED Strip Lights 24 Key IR Remote | eBay
But the one you linked to has the same LEDs and the larger controller I am using now.
Old 01-27-2013, 01:15 PM   #649
PHS79's Avatar
I just ordered the lights that wa3pnt linked. I may have found another solution for mounting the controller, there is a wall inside the camper where the rear awning support is located. And that wall buts up to the rear storage compartment, so I think I can work with that area and then run the wires and sensor wire out like herk did.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 01-27-2013, 01:42 PM   #650
Owner/Operator
Ordered the ones I linked above. Estimated delivery 14 Feb to 3 March.
But, I'm still at least that far out on delivery of the new 8289WS, so the timing should work out.
RodeoGeorge
awning, led pad
