Old 03-13-2013, 05:32 PM   #711
crushor's Avatar
I concur ... That is a great idea. Thanks as well...
Chris
2007 Ford F250 4x4 Harley-Davidson Powerstroke
2006 Cedar Creek Silverback - 35 LRLBS
(2012 -11) (2013 - 10 so far)
crushor is offline   Reply With Quote
Old 03-13-2013, 06:16 PM   #712
Originally Posted by cfsoistman View Post
Placed my order as well yesterday. Any Georgetown owners out there using these? Any hints or advice where you ran your wiring down?
I ran the wiring along side the power awning wires and down into the storage area and out to the step light. Removed the bulb from the step light and wired the awning lights and the led strip lights I added in the step cutout and put the light sensing electric eye between side the step and the cutout . Works great and if I want to shut them off, I just turn off the step light switch inside the camper.
Old 03-13-2013, 06:48 PM   #713
Mounting the LED lights on the Trailer
Does any have a picture they can post of the lights mounted on the trailer under the awning? Originally I had put mine on the roller bar of the awning. After about 6 trips they stopped working and I think that may have been from them being wrapped up in the awning. I now have a replacement set and am thinking of putting them on the trailer under the awning. If anyone could post a picture that would be great!! Thanks.
dec1952 is offline   Reply With Quote
Old 03-13-2013, 07:11 PM   #714
crunchman12001's Avatar
Hi OldCoot,
Would you happen to remember the part # of the photo eye? My google search turned up 81,400 results. Do you have a pic of the install and is in just wired inline. I will be using a 110V plug for my LED power. Would your 12V eye work for my 110V application?
Thanks for your time.
crunchman
2015 F-250 FX4
Old 03-13-2013, 07:13 PM   #715
Hi, The first 100 post on this thread have many pics and a few videos of lights in action. Herk7769 did a great write up so did OldCoot.
crunchman
2015 F-250 FX4
Old 03-13-2013, 08:02 PM   #716
Originally Posted by crunchman12001 View Post
Hi OldCoot,
crunchman
The electric eyes I have (4 or 5 extra) are all 12v. You should be able to get 110v ones @ Lowes,HD or Quick Change Photo Eye
I will take a picture tomorrow of the location of the eye.
Old 03-14-2013, 12:57 AM   #717
SYE
SYE's Avatar
This is the one that I bought, it is a 5-18V unit, it took 2-3 weeks to get here but I was not in a hurry. It is a dusk to dawn not a motion detector.
Dusk to Dawn Light Control Sunset Twilight Switch Day Off Night Work DC 5V 18V | eBay
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 03-14-2013, 02:04 AM   #718
Owner/Operator
RodeoGeorge's Avatar
If you are looking for a motion sensor, here is the link to one from the same company.
I just ordered the Dusk-To-Dawn switch from the above link, and it's being shipped from California. They have a warehouse there for SOME of their items.
Here's the motion switch, which from their description may also include the Dusk-To-Dawn feature (not sure).
12V Save Energy IR Motion Sensor Automatic Light Switch | eBay
RodeoGeorge
RodeoGeorge is offline   Reply With Quote
Old 03-14-2013, 04:06 AM   #719
Thank you for your time OldCoot, syencer and RodeoGeorge.
I am looking at the dusk to dawn switch for the LED lights but the motion switch would work for another project that I have been thinking about for adding a light to my steps.
Thank you all for the time and effort of your post.
I will try to figure out how to get this thing wired (cutting into power of the trailer) and positioning the sensor and IR for the LED's when I get the lights from China. Hope the boat is not too slow.
I did order the 110V power supply due to my lack of electrical skills. Wondering if I should order a 12V supply as an alternative?
I was thinking of just adding another 110V plug behind an access panel behind the awning wires where Herk put his through the wall. (I can see them behind the panel) I know how to add a 110V plug and box, just need to tap off of a plug from the kitchen area.
Once I get the supplies, I will know what I have to work with so questions to follow.
TIA,
crunchman
2015 F-250 FX4
Old 03-14-2013, 10:24 AM   #720
Owner/Operator
I hope that I can explain this sufficiently without pictures, but I'm waiting for my RV to do the mod and consequently have no pictures.
Crunchman, if you interrupt (cut) the +12V wire going to your existing step light and insert the motion switch in that line, then also attach the LED Lights to the output of the motion switch, both will turn on At Night when there is Motion within about 20' of the motion switch.
There is no need to install a 110V Receptacle and then use a 12V Power Supply to obtain the 12V required for the LEDs. You have the 12V right there at the Step Light, and the entire mod (Original Step Light and LEDs) can be manually switched off by the original Step Light Switch when you do not want the lights coming on or when in storage.
RodeoGeorge
awning, led pad
