Old 03-26-2013, 10:21 PM   #781
Originally Posted by herk7769 View Post
For those who may not know:
Murphy's Law
What ever can go wrong;
will go wrong;
in a way that will cause maximum damage;
and be impossible to repair.
There are several Corollaries.
As anyone who has lived a reasonably long life will tell you: Murphy was an Optimist. Reality is much worse than that.
Murphy's law - Wikipedia, the free encyclopedia
Agree wholeheartedly Herk. I never thought of him as an optimist, I just thought he was trying to get the best of me and a few times he did. lol
Old 03-26-2013, 10:51 PM   #782
ryand's Avatar
After reading tons on this... Has there been anyone who installed with a manual awning and did a perm install by drilling a hole in the side wall and pulling power from somewhere?
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 03-27-2013, 10:37 AM   #783
QuietTimes's Avatar
RF Remote
For those that have the RGB led strips here is a replacement remote that is RF instead of IR.
Wireless RF Touch Panel LED RGB Dimmer Remote Controller for RGB LED Strip Light | eBay
Heather & Jim
2012 Ford F150 EcoBoost
2013 Rockwood 2703WS
Days camped 2012 - 14 (not enough); Days camped 2013 - 41 (May - 3; June-16; July-10; Aug.-12) Still not enough...
Days camped 2014 - 23
QuietTimes is offline   Reply With Quote
Old 03-27-2013, 08:23 PM   #784
crunchman12001's Avatar
Got the lights in the mail today.
Hi,
Just an update.
I received my LED's today from 5050 SMD IP65 Waterproof RGB 5M 300 LED Strip 24 44 Key IR 12V 5A Power Supply | eBay for $27.28 delivered. (Herks link) It took 15 days from time of order.
I also received the extension cable (plug & play) for the lights from Amazon.com: 2.5M 8.2ft extension cable connect 4pins plug led strip lights RGB5050 3528 link RGB25GM electrical copper wire link connection led lamp: Electronics
The extra cord will be a easy way to run the wire down from the top of the trailer trough the electric awning arm to inside the trailer.
I plan to run a new line off the 12V panel for power and tuck the IR sensor back out the hole like Herk did.
I did originally order the 110V converter but I am going to go with a 12V power option instead and bought this to plug into the controller for my 12V wire. (the led's did come with an optional 12V pigtail that was not pictured in the ad.)
I also bought a set of Blue Waterproof 30CM/15 LED Car Motors Truck Flexible Strip Light DC 12V that I will use for the step lights that I bought here: 4pcs Blue Waterproof 30cm 15 LED Car Motors Truck Flexible Strip Light DC 12V | eBay
and will install a switch with this switch to match the other switches.
I bought the 3m tape, split wire loom and wire to run the lights under the TT/steps.
As soon / If the weather breaks, I will post the install pics.
Lights look cool in the house, be nice to get installed.
crunchman
PS. My led's did not come with a CR2025 battery for the remote.
2015 F-250 FX4
crunchman12001 is online now   Reply With Quote
Old 03-30-2013, 12:53 PM   #785
Question on LED step lights
Hi all,
I ran a 12 Gauge wire (red +) from a empty slot ( 12V DC side of the panel) to one side of my toggle switch. I ran another wire 12 Gauge ( from the other side of the toggle) to the positive side of my LED controller for my awning lights.
I then ran a 12 Gauge white wire from the main ground NEG - on the 12V side to the negative on the controller.
No problem, turns off awning lights with switch or I can use the remote.
Here is the Question.
When I ran the first wire 12V red + to the 1st side of the switch, I pig tailed a 12 Gauge off of that wire before the switch for power to the 1st side of a 2nd switch (new for the step lights)
I then ran a 14 Gauge RED + (ran out of 12 g) ( 2nd side of 2nd switch) back to where I want to have power for my step lights. (that would work off of the 2nd switch)
The short led strips linked in previous post have 1 red and 1 black wire coming off of them.
Would I need to run a white (- neg) wire down to same location for the NEG -?
I would like to put 2 strips per stair location.
Soooo,
Would the red on the new strip lights be Pos + and the Black Neg-?
I am thinking,,, Red + (return power from switch) to red on strip light? ( pigtail 2 sets together (red +) and pigtail (red +) to other stair well and connect the same way?
Would I just connect the white neg - from 12DC panel to the black - on the strip lights and wire like the red +? (pig tailed)
Sorry for the confusion.
crunchman
2015 F-250 FX4
Old 03-30-2013, 04:35 PM   #786
Owner/Operator
RodeoGeorge's Avatar
In my opinion, you do not need to run a 12- wire all the way from the fuse panel to the LED Strip Pig Tail.
You can pick up the 12- from anywhere on the frame of the RV, or if you have aluminum substructure for the floor you can get it there.
I use a self tapping screw into the aluminum, and attach the black wire with a wire lug. You of course may have to extend the black wire some.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 03-30-2013, 11:04 PM   #787
RodeoGeorge
RodeoGeorge,
Thank you for your reply.
Can I get a ground off of the steps? That should be fine right?
I would use the wire lug and self tap screw.
TIA,
crunchman
2015 F-250 FX4
Old 03-30-2013, 11:05 PM   #788
TURBS's Avatar
Originally Posted by crunchman12001 View Post
RodeoGeorge,
TIA,
crunchman
Why not ground right to your frame?
Old 03-30-2013, 11:10 PM   #789
I could do that too. Just asking where / or if it makes a difference.
2015 F-250 FX4
Old 03-30-2013, 11:12 PM   #790
Owner/Operator
RodeoGeorge,
TIA,
crunchman
Grounding to the steps would be "iffy". We don't know how good an electrical connection there is between the step frame and the RV frame.
You can try it, and if the light do not operate, or are erratic, you most likely have a poor ground.
As was just mentioned, best to go to the Frame itself and avoid potential difficulties.
RodeoGeorge
awning, led pad
