04-09-2015, 11:34 AM
#1862
Originally Posted by Helmsey
FYI this is what the strip will look like. This is a 16.4' strip under a 21' awning, obviously not centered but you get the idea:
One of these days I'll get around to adding another partial strip to have complete coverage.
Oceanlakes in Myrtle beach??
Tim
Tim
04-09-2015, 06:29 PM
#1863
Summer2Go
I am trying to figure out something for a 13' awning. Got any ideas?
04-10-2015, 03:49 AM
#1864
Hi,
Just buy a kit like this and cut it to the length you need. There are marks where you can cut the strip.
crunchman
2015 F-250 FX4
04-10-2015, 10:29 AM
#1865
Tim
You got it! We LOVED it there.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
04-10-2015, 06:06 PM
#1866
The condo in the background gave it away. Along with the golfcart!
Tim
Tim
04-13-2015, 05:46 AM
#1867
Mini Lite Awning LEDs
Yes, I read every post in this thread before installing my lights. I installed my lights underneath the awning rail using a 5 meter string of waterproof 5050 RGB lights. Used the adhesive tape that came with them. So far so good, real test is this weekend. Bought an RF WiFi controller and mounted it inside the storage area where the power wires for the awning enter. I did not have access to any unswitched power there so I had to run a lead to the trailer side of the circuit breaker where the positive lead from the battery attaches. Ran another to the ground terminal. Was worried about how bright they would be but looks good so far. I can easily add another strip if needed. Do not route your wires like you see in my first photo or they will be pinched when the awning closes. They need to go up and over into this channel. Fortunately I caught this before it was too late.
[IMG] [/IMG]
[IMG] [/IMG]
2013 Rockwood Mini Lite 2503S
2005 Jeep Grand Cherokee Limited 4.7 L
Equalizer 10,000# Hitch
04-13-2015, 11:11 AM
#1868
Looks good!
2015 Chevy 3500HD
04-13-2015, 06:00 PM
#1869
Good job, Looks nice!
crunchman
2015 F-250 FX4
04-14-2015, 09:20 AM
#1870
Originally Posted by textman
OK after spending days reading this thread. I would like to know the opinions of the folks who used the channel to mount their LEDs. was looking at this channel
https://www.1000bulbs.com/product/66312/KLUS-B1888ANODL.html
Notice most folks are using the GIP, which seems to be wider. Was wanted to see what others think?
Textman, did you ever try the micro channel?
New to us
2012 Sierra 365SAQ (kids go play in your room) pulled with an 2011 GMC Sierra
Previous Campers;
2008 Wildcat 32QBBS(your pregnant again), 2004 Wildcat 29BHBP (oooh twins), 2000 Travel Supreme (pre kids)
04-14-2015, 10:04 AM
#1871
Also just found this wall mounted control for anyone else like me that doesn't want another remote. This is for the rgbw lights
http://www.amazon.com/SUPERNIGHT-Wal...1WGNBCTP0YFE52
New to us
Previous Campers;
04-14-2015, 11:01 AM
#1872
I have looked at these lights so much my head is spinning. I am looking for plain white, or warm white waterproof lights. No dimming, no fancy colors. I just want to replace the ones that are crap and not working properly on my roo23Ikss, that are hardwired into the wall switch. Which ones do I buy?
2014 Rockwood Roo 23IKSS
2012 Dodge Ram 1500 Hemi 4X4
Me, Hubby and Luna the Lab
04-14-2015, 07:20 PM
#1873
I put a set on the 5 er last summer.Bought some 3m double sided tape and everything worked great.UNTIL it hit over 100 for a few days.When I went out to the camper all the lights had let go and fell to the ground. Haven't got around to messing with them this year.Now I'm thinking I need to get the back up.What the heck can I use to keep them up?I'm going to go to a body trim shop and see what they have.Any other suggestions would be appreciated.
04-15-2015, 03:25 AM
#1874
DaveandSue,
I used this 3M tape 2 years ago, still holding strong. You have to prep the area with rubbing alcohol before applying the tape.
Good luck,
crunchman
2015 F-250 FX4
04-15-2015, 06:23 AM
#1875
The tape I used stayed up.the lights fell off.
04-17-2015, 09:14 AM
#1876
Just received my lights and they don't work properly. When I hit the W button on the remote they get stuck in flashing mode and the receiver does not respond to the remote.
Also they appear do just have RGB leds even though the instruction sheet says they should have Static White. Here is a link to what I bought:
3528 RGB 300LED SMD 5M 500CM Light Strip Waterproof 44Key IR 12V 2A Power Supply | eBay
FR Stealth 2313
Chevy 2500HD Duramax
04-17-2015, 09:26 AM
#1877
Originally Posted by hammick
If you just want white, bypass the control box and hook up 12v to the power lead and ground red,green and blue wires
04-17-2015, 09:30 AM
#1878
I don't see in the listing where it says white.
Rgb is red blue and green
All the lights together make a "white"
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
04-17-2015, 09:52 AM
#1879
Thanks but I was able to get them into RGB all on solid and that certainly isn't white. My controller is very quirky. If they get stuck in flashing I have to disconnect the leds from the receiver and then use the remote to change mode with the leds disconnected.
I do have a set of white leds from China. I will probably try to hook those to this receiver.
FR Stealth 2313
04-17-2015, 10:31 AM
#1880
Either my receiver or my remote is whacked. No rhyme or reason on which button will put them into a quick RGB flash mode. Once this happens the light need to be disconnected and then a different mode selected with remote. Reconnect and then lights will be in that mode. The W and all buttons below W seem to consistently send them into a tizzy.
Even if the seller is willing to send a new receiver it will take a month.
Oh well at least they were only $14.
Neat idea if they worked.
FR Stealth 2313
