09-21-2015, 02:39 PM
#1961
Originally Posted by kdp3078
Sorry, I should have explained better. Wiring in to the light I don't have a problem, it is getting some type of extension, or splicing in the middle of the strip, so I can go straight down from the LED Strip in to the light housing.
I don't want to have to run the strip all the way down, and then run an extension back 8 feet to go in to the housing if there is a better way.
I see what your saying.. I thought about doing it that way but decided to run the 12 volts inside the camper in the cabinet and mounted the controller in the cabinet .. then ran the jumper from the lights inside to the controller.. From the outside all you see is the small wire on one end going in to the controller..
Joe
04-04-2018, 11:06 PM
#1962
Hate to sound dumb, but where do you mount the eye so you can change the lite mode from out side! The eye has only a 6 in lead from the controller?
04-05-2018, 04:11 AM
#1963
I went through the hole where the wire came in for the electric awning. I mounted the controller inside and ran the IR eye through the hole to outside. Others used the porch light ect.
It will take you awhile but if you read this entire thread you will see many ways to mount the lights and get power to them.
2015 F-250 FX4
04-05-2018, 06:03 AM
#1964
Agree with Crunchman,but I think after the "Novelty" wears off the controller key pad will be inside the unit in a drawer! Most find what they like and leave it set there! Youroo!!
04-05-2018, 04:58 PM
#1965
Agreed, I leave mine set on Blue.
2015 F-250 FX4
04-09-2018, 10:29 PM
#1966
Just drop $6.95 on an RF controller upgrade like this one and you are good to go. No drilling or line of sight required...
https://www.ebay.com/itm/2-4GHZ-RGB-...ss!61354!US!-1
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
04-15-2018, 07:04 PM
#1967
I've not read all 200 pages of this thread but I have gone through quite a few and haven't seen this question answered. We have a '17 Cruise Lite and the awning light seems to be simply a white light strip with on & off (no LED remote was provided or found). Is there anything that might indicate that this light could be multi color? I'm hoping maybe I could change it to blue or green and not have it so bright.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
04-15-2018, 07:16 PM
#1968
Most of the factory ones are just one color, white. At least that's what they put on my 2017 2109s.
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
04-15-2018, 07:18 PM
#1969
Ray
That's sort of what I figured but I was hoping for other options.
Could I buy a multi color set and just replace the current lights? Seems like that would be simple since the wires are already routed...
'11 F150 5.0
04-15-2018, 07:45 PM
#1970
Lots of options for multi-color with remote...
you will find options from $5 to $150...
they are basically all the same...
start here...
https://www.amazon.com/RoLightic-SMD...VTNK5SPCYCWJ8B
2014 Shamrock 183
04-15-2018, 07:56 PM
#1971
Just so you are not surprised. You can not connect a multi colored strip to the two conductors from your current strip.
The current strip has two wires running to it ( +12V & Gnd) and no controller. Multi colored strips require 4 wires ( 3 control & Gnd) from a controller. You can use the two existing wires to power the controller. Many of the inexpensive controllers are not waterproof and will cause problems if mounted outside. You should use this info when planning your upgrade.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-16-2018, 04:10 PM
#1972
Got the rf controller and it works great! Thanks
04-16-2018, 06:33 PM
#1973
Thanks all, I appreciate the suggestions!
'11 F150 5.0
04-24-2018, 05:33 PM
#1974
How are they powered?
04-24-2018, 05:55 PM
#1975
RF controller for single color lens
My new Crusader only came with white LED strips under the two awnings. One setting only - on/off (well thats two technically i guess). I installed these https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Just wired them in-line behind the switch panel. (inside the RV) As I have two awnings with two LED strips and two separate on/off switches I ordered the two pack. Could have ordered the single but it would have required me to rewire behind the panel to put them on one switch. Even so, the two controllers are the same frequency and one remote will control both at same time. So I have a backup remote if I needed. For 8 bucks it works great and at least now I can dim my lights.
https://images-na.ssl-images-amazon....EL._SX522_.jpg
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
04-24-2018, 05:56 PM
#1976
Do a search for Rollemup. I've used these for years. They slide in the awning tube and hold a wide variety of lights. They roll up with awning. Fairly inexpensive
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
04-24-2018, 06:01 PM
#1977
You will have to read the thread for how we ran ours, many ideas. Long story short, 12V or 120V.
2015 F-250 FX4
04-24-2018, 08:02 PM
#1978
I bought these https://www.banggood.com/Wholesale-2...r_warehouse=CN from a tip on this forum. So far has lasted longer than the factory installed ones. Very easy to install.
2017 GMC Yukon
2018 Roo 23 ikss
06-21-2018, 01:09 PM
#1979
I would like to mount LED strip lights wired in to 12V. Plan on removing porch light since it is all but useless. Would like to use 16 ft. strip, but connection at porch light position seems to require cutting strip and adding connectors. Has anyone tried this?
06-21-2018, 07:44 PM
#1980
Kasual Kamper
A Google search turns up nothing under that name. Got a link?
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
