Old 06-16-2012, 09:17 AM   #321
TURBS's Avatar
U could. Just specify 12v not 110v
Old 06-17-2012, 10:16 AM   #322
Originally Posted by crushor View Post
Alright, you guys are killing me. By looking at my signature block you will notice that I am a car junkie, and none of them have been left alone. I absolutely MUST install these LEDs on my CC. Aside from eBay, where else are these strip lights available?
My daughter just found this site
hitlights.com Baton Rouge,LA based LED co. Says 4-5 day delivery. Getting ready to order them today. Just trying to compare them and try to order the same set from the local vendor. Will keep all posted. Steve
sdagro is offline   Reply With Quote
Old 06-17-2012, 10:28 AM   #323
TURBS's Avatar
what there price for a 16 footer ?
never mind ........ it looks like $15.00 more than the ones we bought .
Old 06-17-2012, 01:29 PM   #324
Herk7769's Avatar
All right.
If you were careful when you attached the first LED strip under the awning rail and followed the slotted awning material retainer, there is JUST enough room for a second strip!
I cut the sockets off the four wires of the two strips and soldered them to a piece of four wire TELCO solid telephone wire.
White (ground) to BLACK telco
Green (green Vcc) to GREEN telco
Red (red Vcc) to RED telco
Blue (blue Vcc) to YELLOW telco
Taped; heat shrunk; and gooped with RTV Silicone II for waterproofing and security. Ran the TELCO down the arm and into the motor power cord hole in the arm. In the Basement compartment I installed the new 44 IR remote module ad routed the IR sensor back out through the same hole.
I used the RTV to attach it to the bottom on the arm support.
No control switch is required since I can just reach into the compartment and yank the plug out when I am not using it.
The double strip of lights and all the new cool features just really rocks IMO. Plenty of light with the awning extended or rolled up.
AS I stated before get http://www.ebay.com/itm/270939580723...fsrc=1&afsrc=1
or the same LED strip with the 44 IR controller.
http://www.ebay.com/itm/NEW-44-Key-I...item4ab81ea0c6
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-17-2012, 02:50 PM   #325
CRZ
CRZ's Avatar
^^^^ C'mon, let's see some pictures of the install.
CRZ is offline   Reply With Quote
Old 06-17-2012, 03:33 PM   #326
leanne's Avatar
Me too....
I had to jump on the band wagon and get a set now too. My husband is sitting behind me shaking his head......
leanne is offline   Reply With Quote
Old 06-17-2012, 04:26 PM   #327
Aren't these common anode (+) where white is +Vcc and RGB are ground?
Homey55 is offline   Reply With Quote
Old 06-17-2012, 04:47 PM   #328
TURBS's Avatar
Bout time!
Tell him he can stop shakin his when there installed and up and the whole camp ground is envious!
Old 06-18-2012, 06:10 AM   #329
Yea. I have some time restraints tho. They are only 45 miles or so from me. Plus it has a plug & play mode?? Blinks to music. Thought that might be good during tailgating. We will see. Steve
Old 06-18-2012, 03:45 PM   #330
Ft W crew's Avatar
Amazon.com: Ledwholesalers IP67 Waterproof 16.4 Ft RGB Color Changing Kit with LED Flexible Strip, 44 Button Controller + Remote and 12 Volt Power Supply, 2038kit: Home Improvement
After reading 33 pages I too decided to pull the trigger (or in this case push the enter button). After reading the description carefully it appears to be the same lights as Herk, just quicker shipping time and $10 more. It appears I will have these lights installed faster than what it took me to read all these pages. Looking forward to 4th of July camping trip with my fancy lights.
Has anyone programed it to flash Red, White and Blue yet?
2012 Freedom Express Liberty Edition 292BHDS
2011 GMC Yukon XL 2500 4X4 (what a difference)
2007 Ford Expedition EL Eddie Bauer 2WD (sold)
Ft W crew is offline   Reply With Quote
Old 06-18-2012, 03:50 PM   #331
Herk7769's Avatar
Those are not the ones I bought. I got the brighter 5050 LEDs (not 2038s) and a rubberized waterproof strand. Those seem waterproof as well, but my strand has a rubber cover.
Old 06-18-2012, 04:17 PM   #332
TURBS's Avatar
No ! but that would be fitting!
Old 06-18-2012, 06:33 PM   #333
toniundpetra's Avatar
Now I had to get some Led's too. I'll put them in clear shrink tube sock. That will keep the moisture out when it is rolled up and stored. I'll run a 12v from the battery with fuse block to the transformer. Run the wire extended up to the awning motor connection through the tube. Put a easy off quick disconnect on the moving side. It will disconnect if the love of my life pulls the awning without disconnecting.
KIS that is the motto.
toniundpetra is offline   Reply With Quote
Old 06-18-2012, 07:18 PM   #334
cootr68's Avatar
I ordered white led solar/battery powered waterproof 20 ft. Going to mount them on the frame rail. When traveling I will put the solar charger in the back of the truck and when set up put it on the a- frame. Hope it works. http://www.ebay.com/itm/Lighting-Ess...-/280901744051
1997 Sierra m-27fls tt
1999 Pontiac T/A
2006 flstn Deluxe
2004 Polaris 330 magnum
Bear the Labrador
cootr68 is offline   Reply With Quote
Old 06-18-2012, 07:37 PM   #335
Originally Posted by cootr68
I ordered white led solar/battery powered waterproof 20 ft. Going to mount them on the frame rail. When traveling I will put the solar charger in the back of the truck and when set up put it on the a- frame. Hope it works. www.ebay.com/itm/Lighting-Essentials-Solar-LED-Rope-Lights-20ft-Long-/280901744051
I think you will not have enough light from the Led lights. Everybody buys 60 LED per meter. Hope it works.
Old 06-18-2012, 07:43 PM   #336
cootr68's Avatar
Just a soft glow will be fine. If they don't work out I can put them under the top rail on the deck at home.
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
Old 06-18-2012, 08:18 PM   #337
Herk7769's Avatar
Did you folks see this?
Music Audio Sound Driver RGB x3 Strip Light LED Controller 12V 60W IR Remote | eBay
Difference between the waterproof code IP65 and IP67? Anyone?
The two similar white ones are IP65 and the copper colored one is the IP67.
ID:	15428   Click image for larger version
Old 06-18-2012, 08:29 PM   #338
Rsgtivr6's Avatar
Not really sure if I would do the music control myself. Just want a nice ambient light when sitting around the campfire at night. When I was in high school, I would have been more apt to toss this under the car and hook it up that way, but I don't have a set of 12's with a 1000 watt amp in the trailer nor do I plan on thumpin the bass at a CG anytime soon, lol. Maybe for tailgaters this would be pretty cool.
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 06-18-2012, 08:38 PM   #339
Coops1's Avatar
In enclosures IP54 is splash proof, IP56 is for direct water spray so maybe 67 is underwater?
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 06-18-2012, 08:55 PM   #340
Check out:
http://en.m.wikipedia.org/wiki/IP_Code#section_1
awning, led pad
