05-06-2013, 02:35 PM
#1201
Cutting Double Sided tape in strips while on roll
I tried to cut a roll of 1" wide 3-M double sided tape into a narrower 3/8" strip while still on the roll using an exacto knife... While I could do it in 12 inch or so strips before the rubber table would not release the knife. I would prefer to have a full 15' on the roll ready to unwind and apply go when attaching the LED strip to the awning bracket underside. Has anyone found an easier method to do this (cut tape) or did you do it in a piece by piece effort?? Thanks
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
05-06-2013, 02:47 PM
#1202
Narrow Tape
Try a local hobby store...they do make a narrow two face tap in a roll, its not 16'-0 long, think its only like 5'-0...at least you could get three and do it....If you are using LED's like the rest of us, they came with a sticky back...if that has come off for some reason, try something I found at Home Depot..It is in the countertop department, it is made by Fasade...It is used to hold a decorative product to the wall in a backsplash configuration...It is wider than 1", so I took and folded it over, it sticks to itself and still has two sides sticky...
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
05-06-2013, 02:51 PM
#1203
I cut it on my vertical band saw and keep pulling it apart after the cut.
05-06-2013, 03:18 PM
#1204
Tape
Mine came with tape already on it. Then I went ahead a put a small dab of polyurethane on each end.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
05-06-2013, 04:23 PM
#1205
I just ordered a roll off of Amazon 3M 03614 Scotch-Mount 1/2" x 15' Molding Tape
Good to go!
crunchman
2015 F-250 FX4
05-06-2013, 05:00 PM
#1206
I made a jig that held a 3 ft section and used a aluminum yard strict held down with three clamps. Using a carpet knife I coupled cut 36" at a time. Then I would slide the tape up 36" clean the blade with Goop sticky remover and then cut
The next section. Whole thing took maybe 15 minute once a got the system down. My work service was an old piece of Formica counter top. Didn't have to press to hard. Good luck.
2013 SP 240 Anniversary
Tundra CrewMax 5.7L in Pyrite Mica
Clark, Mary Jane & Max our German Short-haired Pointer
(2011-42)
05-06-2013, 06:16 PM
#1207
I was able to find the 1/2" 3M tape at my local Autozone
3M/1/2 in. x 15 ft. molding tape
2017 Sierra 357TRIP
2016 Ram Tradesman 250
05-06-2013, 07:53 PM
#1208
Use a band saw, Vertical one if you have it.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
05-06-2013, 08:00 PM
#1209
Funny that the tape thing should come up again today. About 3PM I got a call from my dad, he walked past our TT which is parked under the lean-to on his shop, after just installing the lights about 10 days ago, after cleaning the surface with alcohol 2 times and only having moved the camper about 500ft total, dad said that about 2ft of my lights were hanging down from the camper. Our first trip is on the 17th, and this Sunday I am bring the camper into our house to start loading it up. But now it looks like I will be making to trip AutoZone to get 3M tape and reinstalling them on the rail with the new tape.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
05-06-2013, 08:06 PM
#1210
Mine sagged on the ends as well, until I used clear silicone to affix them. Just a dab on the last six inches seems to help. Pulled 60 miles or so and been 4 weeks and they still are there and feel solidly attached.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
05-06-2013, 08:13 PM
#1211
Originally placed mine directly on the Gel-coat just under the awning...probably about two inch's...pulling the lights back off next weekend and placing them directly to the awning attachment rail attached to the side. Think that will look a bit better to me....Purchased another set to replace the one that I take off, that way the adhesive back will be fresh..also have the 3M tape just in case I need it...I can use the old set that I take off somewhere else...like on the other side maybe???
05-06-2013, 08:22 PM
#1212
I used a set in the pantry and threaded it around to the bottoms of the shelves and put a microswitch on the door.
05-06-2013, 08:29 PM
#1213
Engineer of Crazy Train
Ran into my first issue. My silicone didn't set right around my hole. Well, I think it was the unexpected thunderstorm (should have watched the weather) less than an hour after applications. Should I try again with silicone or use something else.
http://campinglifewithmatt.blogspot....ng-lights.html
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
05-06-2013, 08:34 PM
#1214
Camping Life with Matt: Trailer Mod - LED Awning Lights
Pull them down, clean with alcohol and use 3m 2sided outdoor tape.
05-06-2013, 08:35 PM
#1215
OC, it was the silicone on my hole and wire grommet.
Locomotive Engineer
05-06-2013, 08:49 PM
#1216
My mistake, should have clicked on LKicklight's post.
05-06-2013, 08:52 PM
#1217
You all are causing me to spend way too much money Got mine most of the way completed today with the exception of finalizing the 12V connection.
I think I have learned from everyone on this thread though which has been a good part of me getting this on later. Too start with I have a 21 foot awning (had to put two sections together.) So I got to work on my soldering skills.
Next I decided to use some outdoor sprinkler low voltage wire to run from the lights, down the awning poles and into the camper. More soldering:
Finally I used the 3M tape that came with the lights, and also used silicone on both ends of the lights. I also used some to cover the small break/gap in the two sections and put a couple of beads of silicone about every 3 feet to help keep everything secure. Made sure to put enough silicone around the hole where the current power wires run through the camper after pulling the cable in.
Last but not least, run a quick test to make sure that everything worked (no solder yet, just some electrical tape.)
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
05-06-2013, 09:36 PM
#1218
Cutting the 3M tape
We had the same problem with the knife getting stuck in the tape when we first tried to split the tape width, and we didn't have a band saw. Our second attempt went much better - we cut pieces about 12" long (easier to work with that way anyway) and taped it to a piece of the "release" non-stick aluminum foil. From there we just used a utility knife and split the pieces. Came right off the aluminum foil without any problems.
2007 Chevrolet Silverado 2500HD Duramax Diesel
2012 Cedar Creek 30RL
Full Timers Since October 2012
05-06-2013, 10:06 PM
#1219
I doubled my lights.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-06-2013, 10:46 PM
#1220
Phat Phrog Stunt Crew
I have seen many of the posts in this thread asking about weather sealing. I think I found a good solution. It is called Liquid Tape. You make your connections, then coat with this. I turns into solid rubber and completely seals. Available in many colors.
White Liquid Tape 4 oz Container | eBay
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
