05-12-2013, 07:24 AM
#1261
I like having mine in the awning slot. Allows a degree of aiming with my power awning. I can extend it a little less and aim at the camper, or extend a little more and aim towards the ground.
05-12-2013, 07:34 AM
#1262
The only 2 drawbacks are when the awning is stowed, no lights and having to plug & unplug when deploying & stowing.
05-12-2013, 02:52 PM
#1263
Back yard camping with my new LEDs
05-12-2013, 03:10 PM
#1264
We have nothing but time while camping right ?
If the awning is stowed then I don't need lights
05-12-2013, 03:54 PM
#1265
Not necessarily if you are just staying overnight on a trip to FL like we do or on a trip somewhere else.
05-13-2013, 03:14 PM
#1266
Good Call
Originally Posted by herk7769
I had this problem with one segment of my first strip. Although all worked fine before I mounted them; when I stuck them up one of the leds was not making good contact with the printed circuit. (there are 4 pins on each led cluster).
I believe it was a cold solder joint.
I pressed on each one until I found the one that lit up when I put pressure on it.
Once it lit up, it worked until I moved the trailer. I had to repeat the pressure after every stop to get it to work for about a week. Suddenly "It is fixed" and have had no trouble now for over a year of camping.
I think the cold solder joint is now "mooshed" together and making good contact.
I tried as you suggested, and I got the 3 segments to light Green. Don't know how long it will last but I know where to go to fix it now.. Thanks .
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
05-15-2013, 06:09 PM
#1267
Does anyone have any idea about the life of the lights? For example, keeping it on all night - are they time limited?
2007 Chevrolet Silverado 2500HD Duramax Diesel
2012 Cedar Creek 30RL
Full Timers Since October 2012
05-15-2013, 06:28 PM
#1268
Well I am very disappointed. The Domestic LED light strip kit $175.00 lasted from October until last weekend. About an inch from the plug they got hot and melted. What a piece if crap for 175. I will stick with the other ones I received from china for 25 bucks they still work!!"
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
05-15-2013, 07:02 PM
#1269
Tape Problem
Well after reading all the posts here I got my lights, did the prep work in the pass thru, cut my lights to length and siliconed the end.
Tonight was the "install" the strip night. EXCEPT the outdoor fancy 3M super sticky tape will not stick to my light strip. Sticks to anything else, just not the strip.
My strip is totally encased in a silicone sleeve. I am trying an experiment with a short piece. Ran some silicone seal on the strip then put the piece of 3M tape on it. Will check in the morning and see if it has good adhesion. If that doesn't work I'm stumped.
Ideas anyone?
Heather & Jim
2017 Ford F150 4x4 EcoBoost
2013 Rockwood 2703WS
05-15-2013, 07:39 PM
#1270
Two Face Tape
Home Depot and Lowes has a two faced tape product this is sold in there countertop department..the product is used with the BackSplash Products by Fascade..comes in several different patterns an colors...Used the tape on my LED light installation for my cargo compartment...the first string would not stick even though I wiped the services down with alcohol twice...used the tape, all is well:
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
05-15-2013, 07:48 PM
#1271
Ideas anyone?
Are you using this 3M tape and wiping everything down with acetone?
05-15-2013, 07:59 PM
#1272
How many of you put the LED's on the actual awning overhang under the fringe and how many of you put them on the side closest to the RV wall?
Jill
Jill and Ed and the kitties
1998 Coachmen Leprechaun 31Q
05-15-2013, 08:00 PM
#1273
I just used the tape that was on the back of the lights and granted it took two of us to get it up there because the weight of the yet-to-be stuck on end kept pulling the rest down. Once it was up there it was sturdy, but I did apply a bead of silicone to both sides of the lights every couple of feet and a enough to cover the ends thoroughly to keep it there. So far it has held up through about 50 miles of towing at 65mph with no problems.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
05-15-2013, 08:40 PM
#1274
Ideas anyone?
3m makes an automotive trim molding adhesive that works awesome. I might be able to get t he part number for you.
Scott & Vicki
2021 4 reserved
05-15-2013, 08:47 PM
#1275
Phat Phrog Stunt Crew
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
05-15-2013, 09:38 PM
#1276
I bought the 3M molding tape at Advance Auto parts, a 15ft roll was just over $11 with tax.
We have our first trip this coming weekend, about 105 miles of interstate each way. So we will see how 3M tape that came on the light strip holds up to that... I put the roll of molding tape in the truck along with one of my work platforms, just incase I have to remount the lights when we get to the CG, hopefully not, but I would rather have the stuff and not need it than need it and not have it!
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
05-15-2013, 09:42 PM
#1277
Thanks for all the ideas. The problem seems to be getting something to stick to the silicone. I'm not using the RGB 5050 that most of you have. It's called Dream 6803. The strip is loosely encased in a silicone sleeve. There is no tape pre-installed on the back of the tape. The exterior 3M tape - red protection on both sides - grey super sticky stuff is the actual tape I'm trying to use. Seems like it should stick like crazy but you would think it was greased the way it won't stick to the silicone sleeve. And yes I wiped down with acetone.
The experiment of putting a bead on the strip then sticking the tape to that seems to be holding. I won't pull hard till it has more time to set up.
Heather & Jim
05-16-2013, 07:38 AM
#1278
Phat Phrog
Wow is that backsplash a mod?
Kenny n Karen
TV: 2017 Chevy Silverado 3500 LTZ - named Betty
RV: 2017 Columbus 366RL - named Karen’s Camper
05-16-2013, 07:40 AM
#1279
Phat Phrog
Originally Posted by awwall
Looks terrific!!!
Kenny n Karen
05-16-2013, 07:41 AM
#1280
Phat Phrog
Let us know how it holds up.....and if you get any comments on how cool they are!
Kenny n Karen
