Old 05-22-2013, 07:22 PM   #1301
Always Learning
Originally Posted by LKicklight View Post
After you cut the LED's to the length you require, some folks try to use them in other places by soilering the ends...here is a much easier way and it looks nice too...
I'm anti-solder... Where do you get these clips?
Old 05-22-2013, 07:36 PM   #1302
crunchman12001's Avatar
Here you go:
For RGB 5050 LED LED PCB Connector adapter 4-Pin No soldering 10mm for 5050 LED RGB Strip | eBay
For single color: 5050 10mm Connector LED PCB Connector Adapter 5050 Single Color LED Strip 2 Pins | eBay
crunchman
2015 F-250 FX4
Old 05-22-2013, 08:03 PM   #1303
LKicklight's Avatar
http://www.ebay.com/itm/10PCS-10mm-2...-/121079701660
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 05-22-2013, 08:43 PM   #1304
Just wondering if anyone has installed lights below the awning on a Georgetown XL 378 with a power awning? If you have, where did you pull the power from?
Marty
2013 Georgetown XL 378 TS
mkaminski is offline   Reply With Quote
Old 05-23-2013, 10:19 AM   #1305
Love the lights
I really liked how the lights looked on your awning. It really added a nice touch. I like the different type of lighting.
SugarhouseAwning is offline   Reply With Quote
Old 05-23-2013, 10:35 AM   #1306
Taylorgso's Avatar
When all else fails, I turn to a product called "Amazing Goop" - works when 3M tape, or two-side velcro does not - just follow directions. Comes in several different colors - buy the one in the blue tube! This stuff hardens rock hard - I've used it to bond attachments to dashboards on several cars - it has never released from any of them. Removes with Acetone. Stuff is generally available at home supply stores, or at Advance, Autozone, etc. You can also use it to bond velcro to those surfaces - use the non-stick velcro, though.
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 05-23-2013, 11:29 AM   #1307
X2. Pulled my hair out fighting with various sticky-tape products. Then I found Amazing Goop. My first application is still holding strong after 13 years (in the Texas heat).
Old 05-28-2013, 06:08 PM   #1308
Does anyone know if these can be cut to length?
5M 5050 RGB Dream Color 6803 IC LED Strip Light Waterproof 133 Change RF Rmote | eBay
Marty
Old 05-28-2013, 06:16 PM   #1309
PHS79's Avatar
Looking at the one picture on the bottom, yes it has the cut/split points in the strip.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 05-28-2013, 06:46 PM   #1310
Which lights have White???
I have gone through two sets of lights that I bought on Amazon. Both sets had white lights and they were held on to the awning bar with the double sided tape. Unfortuneately, both sets died after only a few weeks. So I then ordered the lights that everyone seems to be getting on Ebay. I was hoping to just be able to slide them into the awning track without using the double sided tape-and I was hoping for white lights. Well, my lights came today. It says white on the remote-but there is no white. I am hoping that of all you folks out there that have raved about these lights-which ones have a WHITE light setting and can just be slid into the awning rail track? Any info would be greatly appreciated!!
dec1952 is offline   Reply With Quote
Old 05-28-2013, 06:55 PM   #1311
Tonk Mom's Avatar
Do most people put the LEDS on close to the RV or on the part of the awning under the frindge at its full extension?
Jill
Jill and Ed and the kitties
1998 Coachmen Leprechaun 31Q
Tonk Mom is offline   Reply With Quote
Old 05-28-2013, 07:09 PM   #1312
campfirefun's Avatar
I put ours on the roller. At the outside edge
campfirefun is offline   Reply With Quote
Old 05-28-2013, 07:49 PM   #1313
JohnF's Avatar
Here are the lights I purchased.
5M 3528 RGB Waterproof Flexible Strip 300 LED 44 Key IR Remote Power Supply | eBay
White on the control will light all the lights giving you a white light. It won't look white when you look at the strip but it will be a white light produced.
I had several people stop and ask about my lights while camping at a state park this weekend. They are cool!
ID:	31602   Click image for larger version
JohnF is offline   Reply With Quote
Old 05-28-2013, 08:52 PM   #1314
Owner/Operator
RodeoGeorge's Avatar
What color do you get when you select WHITE?
Can you get all three primary colors (Red, Blue, Green)?
This CAN indicate whether it is a controller issue, or an open circuit between the controller and the Light String.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 05-28-2013, 09:19 PM   #1315
Phat Phrog
RVChick's Avatar
Gosh I feel for everyone who finds this thread, and falls in love with the LED awning light mods!! There is so much to read, and seems easier to just ask the questions again that you need! That is what is so great about this thread!! These questions have been asked so many times, and the amazing FROGs love to teach and give you options! I too have the LED strip lights and have it on my DH To Do List...thank you hun!!! Since he doesn't actually chat on this forum, I am the one repeating all the various ways you can install these lights! My fav...and I am pretty sure I can sweet talk him into it....I'm just sayin.....is to install them along that trim on the wall of the rig and the awning. This way I can turn on the lights even when my awning is retracted!! I also prefer them to be wired via the step light, so that I can turn them on using the light switch inside the rig when I want them on. This allows me to turn on the outside porch lights when needed without having to turn on the LED awning lights! Oh and hun.....I would love it if you could use any leftover sections of the LED lights to light up the underside of my front porch steps!!
I love to see pics and hear campers reactions to them....so please keep posting!! Oh and one day soon when my 'List' is next...I will show pics too!
Kenny n Karen
TV: 2017 Chevy Silverado 3500 LTZ - named Betty
RV: 2017 Columbus 366RL - named Karen’s Camper
RVChick is offline   Reply With Quote
Old 05-28-2013, 09:20 PM   #1316
JohnF's Avatar
I get all the primary colors when I select white. There are no white L.E.D.s on the string.
Old 05-28-2013, 09:26 PM   #1317
Power the awning lights from the porch light switch with the dusk to dawn eye and the step lights on the step light switch.
Old 05-28-2013, 09:27 PM   #1318
JohnF's Avatar
One negative I discovered with the L.E.D. lights this past weekend. They attract bugs! I turn them off about an hour before retiring and leave my amber porch light on for the night.
Old 05-28-2013, 09:27 PM   #1319
Herk7769's Avatar
You are correct. There are no white LEDs.
When the three colors are on at the same time, it makes white.
When all the colors are off; it makes black.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-28-2013, 09:33 PM   #1320
Originally Posted by herk7769 View Post
...When all the colors are off; it makes black.
And THAT brilliant, unknown information, ladies and gentlemen, is from a retired AF pilot!
Sorry Lou, just couldn't resist!
awning, led pad
