Old 09-25-2013, 11:19 AM   #1501
urocav2001's Avatar
Originally Posted by EastlakeRoo View Post
Just installed the led lights on the wall so when the awning is rolled up you cant see them. Very cool. 24 different colors. Another mod complete.
Attachment 14073
Looks awesome!! Can I ask you how you wired them up ? Can u wire them up to a plug?
urocav2001 is offline   Reply With Quote
Old 10-17-2013, 03:54 PM   #1502
I got mine all in thanks to this thread!
Had a small problem with the sticky stuff on the back, over night it came off but i had a ladder in below it and it caught, went back with a heat gun on the trailer and on the LED strip and its been holding for about a week now.. If it falls again ill have to use the better 3M double sided sticky tape..
Ill post my setup and pic in a few days!
Deeks is offline   Reply With Quote
Old 10-18-2013, 03:32 AM   #1503
crunchman12001's Avatar
Glad we could help. Looking forward to the pics.
crunchman
2015 F-250 FX4
Old 10-18-2013, 06:27 AM   #1504
KyDan's Avatar
My led strips came with 3M sticky tape on the back. Bought directly from China-
could be counterfeit but the logo is on the back of the peel off paper.
Mine have hung up there ok for a week. Fingers crossed!
I went with blue only and no controller. It's a very compact nearly invisible
install. I drilled a small hole thru the wall and tied it into an interior light circuit.
This was fairly easy in my case. My hole came thru inside the
bathroom closet where there were exposed lighting wires. Easy to tap
into a 12v supply and easy to add a round hole wall switch thru the closet
wall near the existing light/exhaust fan switch. That wall is single ply with
no hollow core but it has a 1/2 plywood backer in the closet. It was
a perfect place to install the switch. Got a round hole rocker switch from
Radio Shack for $4 and it's a done deal.
We have our 1st test in a CG next weekend. Camping 3 nites off the grid. I'm
looking forward to being one of the only guys in the non electric side with
"mood lighting"
I used 2 strips, one under the awning gutter facing down. It washes the
wall with blue light. The 2nd is on the awning roller. Both strips together draw
right at 2 amps. We should be able to run them a couple hours a nite with
no problems. I'm taking the genny just in case we need to charge batteries
for the 3rd nite-- It might be cold enough we need the furnace!
That's fall camping for you!
BTW, I saw where some had mentioned the silicone light strips tended to
stick to the awning when rolled up and later when opening the awning.
I took a small brush and dusted the strip with baby powder and it took
the tacky feel away. At least it should not stick to the awning this time. I'm sure it will
wash off and need to be re-applied if it sticks in the future...
Peace!
Dan & Rita D
Old 10-18-2013, 03:21 PM   #1505
KyDan,
Nice job on the lights. Looks good.
I have the RGB with the remote but I like the blue setting too. I also added two 12" strips per set of stairs in the blue only. The stairs were invisible with the awning lights off. I think I will add a 2nd strip to the right of the awning to light the other half of the camper up.
crunchman
Name:	LED- Awning and step lights.jpg
ID:	41298   Click image for larger version
Name:	blue LED step lights.jpg
2015 F-250 FX4
Old 10-18-2013, 04:02 PM   #1506
Phat Phrog
RVChick's Avatar
Wow KyDan and Crunchman! Those look great! Great info too!
Kenny n Karen
TV: 2017 Chevy Silverado 3500 LTZ - named Betty
RV: 2017 Columbus 366RL - named Karen’s Camper
RVChick is offline   Reply With Quote
Old 10-19-2013, 06:50 AM   #1507
KyDan's Avatar
FYI, here is a link to the one's I bought--
5M Roll 3528 SMD Waterproof 60 LEDs/M 300 LEDs Warm Cool White Red Green Blue Yellow RGB Flexible LED Strip Light Free Shipping-in LED Strips from Lights & Lighting on Aliexpress.com
$8.75 per roll, including shipping from China. Typically takes about 3 weeks
to arrive US via USPS signature required mail.
They ship to Canada also.
These are 5 meters/16.4 feet long with 300 leds per set.
They can be cut into shorter length but I'm gonna guess you only can
get 2 usable pieces if you cut them as there are connections wired on
each end. If you cut more than 2 pieces you have a center piece with
no connection pigtails.
No controller needed for single color.
I have ordered several items thru this "china version of ebay" and have
had no problems.
YMMV.
Peace!
Dan & Rita D
Old 10-19-2013, 08:23 AM   #1508
AquaMan's Avatar
I bought a set that had the 3m tape on back and the whole set was on the ground later that day. I even cleaned the surface and wiped with alcohol prior to applying lights. Going to add my own tape to it and see if that will hold them.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 10-19-2013, 08:51 AM   #1509
I know someone who has had a set along with a Dawn to Dusk switch for well over 6 months and they still don't work. Could be they need to be installed? I wonder who that might be???
Old 10-19-2013, 08:53 AM   #1510
Had the exact same problem except it took 2 days for them to sag in big loops. 3M double sided outdoor tape solved the problem.
Old 10-19-2013, 10:47 AM   #1511
Would that person be from IOWA?
Flying dutchman is offline   Reply With Quote
Old 10-19-2013, 11:27 AM   #1512
No, it be somebody in mid Missouri.
Old 10-20-2013, 04:25 PM   #1513
Phat Phrog
RVChick's Avatar
BwaaaaaHaaaaaa!! IkR?!?!
Kenny n Karen
Old 10-30-2013, 09:11 AM   #1514
Trickytroy's Avatar
So out of all these pages what is the verdict on the recommended lights to purchase? d
Does anyone have an ebay link available? Cheers everyone!! Thank you in advance!
Trickytroy is offline   Reply With Quote
Old 10-30-2013, 10:34 AM   #1515
Tonk Mom's Avatar
We finally got our awning lights up and they work very well. My husband drilled a hole through the closet. He also wired the lights to an inside switch so we can turn them on and off without going outside. I believe he also connected the lights to the extra battery he installed for the outside freezer.
ID:	42053   Click image for larger version
ID:	42054   Click image for larger version
ID:	42055   Click image for larger version
Jill
Jill and Ed and the kitties
1998 Coachmen Leprechaun 31Q
Tonk Mom is offline   Reply With Quote
Old 10-30-2013, 10:37 AM   #1516
Tonk Mom's Avatar
Part two.
ID:	42068   Click image for larger version
Jill
Old 10-30-2013, 12:02 PM   #1517
Herk7769's Avatar
Originally Posted by Tonk Mom View Post
Part two.
Trying to upload photos but getting an error message.
There are "total size" limits on photographs and "total upload at once amount". Try adding them one or two at a time and press the "upload" button between browsing for the next photo.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 10-30-2013, 12:27 PM   #1518
Tonk Mom's Avatar
Thanks, Herk. I will try again.
ID:	42064   Click image for larger version
Jill
Old 10-30-2013, 12:28 PM   #1519
Tonk Mom's Avatar
More photos
ID:	42066   Click image for larger version
Jill
Old 10-30-2013, 01:09 PM   #1520
Herk7769's Avatar
Looks great!
Oh, and you don't need to limit yourself to 2 photos. Just hit the "upload" button; then when it shows as "uploaded" you can continue to browse for 2 more. Repeat until you hit the 10 photo/attachment limit.
awning, led pad
