Old 08-04-2015, 07:26 PM   #1941
Originally Posted by Wayne & Kimmy View Post
Ur most welcome!
Good luck with the mod, and give us an update on how it turns out. Feel free to PM me if I can offer any more hep!
Thanks for all the info! I installed the lights yesterday (daytime) but I'll have to wait until this weekend to see them in action in the dark. I lucked out with the electrical connection though - directly on the inside of the trailer where I mounted the outside electrical box is the Winegard 12v electrical plug. I just put a cigarette lighter plug on 18" of cable and used that to power the LED controller. The Wineguard plug is rated for 8 amps and I'll only be drawing 4.5 amps max. I'll get some photos on the install this weekend and post them for all to see. Again - thanks for all the help!!!
Ontherock is offline   Reply With Quote
Old 08-06-2015, 07:58 AM   #1942
Wayne & Kim
Wayne & Kimmy's Avatar
Ur most welcome, and I'm glad the power solution worked out so well for you! I can't wait to see and hear how they work out for you when you do the nighttime test this weekend. Ur gonna love playing with them and get lots of compliments from neighbors!
Wayne and Kim
2014 Cedar Creek 36CKTS
2011 Ford F250 King Ranch 4x2 Diesel, added springs
Nights camped: 2014 - 32; 2013 - 23
Wayne & Kimmy is offline   Reply With Quote
Old 08-06-2015, 06:40 PM   #1943
Mrs Evans's Avatar
Supplies are in, ready for installation!
I have really enjoyed reading through all the postings in this thread and decided to install some LEDs on our little TT too! Here's what we chose:
1) Supernight LED strip
2) Klus Channels
3) Clear Lens Cover for the channels
4) Cooligg Wifi Wireless RGB LED Strip Controller
Also bought supplies like cable to run it to our porch light for power, some 3M mounting/molding tape and some pop rivets to secure the channeling to the trailer.
I really like the channel idea because it will make it a lot easier to replace the LEDs in the future if needed.
Will post pics when the project is done and thanks again everyone for all the awesome ideas!
Michelle Evans
Katy, TX
2011 Carriage Cabo 341
2014 Wildwood 231RBXL - Traded Her In
2016 Days Camped = 5; Reserved = 14 so far
2015 Days Camped = 24 / 2014 Days Camped = 23
Mrs Evans is offline   Reply With Quote
Old 08-08-2015, 06:54 PM   #1944
PHS79's Avatar
I put lights on our old Grey Wolf 26BH about 3.5 yrs ago. In June we traded for a "new" camper, so now I get to install them onto this camper also. On our new camper we have 2 awnings (10 ft and 16 ft), 2 entry doors and an outdoor kitchen with no light inside it. I am planning on buying 2 full kits, one controller will run the light under both awnings and if I can run the wires like I hope the outdoor kitchen will get ran off the awning controller. The second controller will run the lights at both entry doors.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 08-12-2015, 12:38 PM   #1945
just ordered the lights to do the same, hope is not too complicated to join with the current light strip (look similar). Thanks for your ideas!!!
Amazon.com: SUPERNIGHT® 16.4ft 5M Waterproof Flexible strip 300leds Color Changing RGB SMD5050 LED Light Strip Kit RGB 5M +44Key Remote+12V 5A Power Supply: Musical Instruments
FreddyCamper is offline   Reply With Quote
Old 08-12-2015, 12:56 PM   #1946
RollingDownTheHighway's Avatar
I installed these under my awning last month. They're awesome. I'm going to do some 'custom' work with the cables in the off season. I got some 3M dbl sided tape and they went up in about 15 minutes. I put 12' under my awning, and the remaining 4' under my kitchen cabinets in my outside kitchen. The local camping store wanted $60 for the same lights, these were 30 and work just the same.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 08-21-2015, 08:39 PM   #1947
I'm halfway through my second camping season with that set and it's acting up already. A lot of the time the strip will do 2 different colors at the same time (left side red and right side blue) . When you have it fade or jump colors a lot of the time the left side won't work at all. Just a heads up for you
Jimbobbucky is offline   Reply With Quote
Old 08-22-2015, 12:53 PM   #1948
Summer2Go
Summer2Go's Avatar
Mine is Tao Tronics, I love it so much, and it cost a grand $28 to do my 13' awning, and under the rv by my steps. I wouldn't mind doing it over every couple of years. We'll see the duration of my product......
Summer2Go is offline   Reply With Quote
Old 08-22-2015, 12:56 PM   #1949
Summer2Go
Summer2Go's Avatar
Oh and it took a couple of hours to cut and stick up. No fancy Klus channels, looks good w/o.
Old 08-22-2015, 09:45 PM   #1950
2) Klus Channels
Could you explain to me how you ran it to your porch light for power? That's exactly what I want to do, but I'm a clueless electrician. Thanks so much!
Jillcookie is offline   Reply With Quote
Old 08-23-2015, 09:07 AM   #1951
Mrs Evans's Avatar
We're actually going to do the install this next weekend - finally! Here's the plan:
First we're going to use one of these RGB extension cables
cut one of the ends off and run it down the awning arm (closest to the porch light) just enough to get it to the porch light.
Then since our 'pantry' is on the other side of the porch light, we're going to drill a hole through the back of the porch light in to the pantry area and continue to run the RGB cable into the pantry area where we will connect the cable to the wireless RGB controller that we'll install in the pantry with some industrial velcro.
Then we'll take some 16 gauge wire and connect that to the wireless controller and then connect the other end of that wire to the ones from the porch light.
Once we have everything in place, we'll test it out to make sure it works and then we'll clean it all up, filling holes and protecting connectors and all that jazz!
Ta-da! I ran the plan by my hubbie first to make sure I picked the right materials, because I am absolutely NOT an electrician. He says it should be good and I trust him. I would like to put it together for the most part, with his help/supervision
I'll be sure and take pictures
Michelle Evans
Katy, TX
Old 08-28-2015, 07:29 PM   #1952
Originally Posted by grege View Post
I used the porch light housing, removed the bulb and socket, and attached power to that. I can turn them on and off using the porch light switch inside the camper. The controller is inside my porch light housing and the sensor sticks out the bottom. I got some very flat wire molding and went from the porch light to the bottom of the awning to run my wires to the lights.
Greg
Hey Greg,
I want to do this the same way you did.. Can you power these up in the middle of the run??
Thanks, Joe
meganjoe is offline   Reply With Quote
Old 08-29-2015, 09:38 PM   #1953
Garrette's Avatar
Great idea.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 08-30-2015, 09:08 PM   #1954
Mrs Evans's Avatar
Talking It Alive!
Finally installed our LED lights!
I will say that the channel covers we bought were a tight fit over the LEDs that we chose - might end up changing that out at some point. Otherwise everything worked out quite well
Here are some pics:
Klus channel for holding the LED strip light
"Porch" light housing - we used the wires to power the wifi RGB controller
Hole that we drilled from the "porch" light housing thru to the "pantry"
The wires from the LED strip light connect to the white RGB cable behind the awning arm and then the cable runs to the "porch" light housing
Final look - already got a compliment from a neighbor and we're not even camping yet, lol!
Michelle Evans
Katy, TX
Old 09-11-2015, 11:37 AM   #1955
How did you apply the new tape?? Over top of the old stuff??
Thanks, Joe
Old 09-11-2015, 12:39 PM   #1956
Thanks, Joe
When I opened the package over half of the "tape" that came with them was off, so I just pulled the remaining off and put the dbl sided tape on
Old 09-11-2015, 12:50 PM   #1957
AquaMan's Avatar
I found mine on the ground the next morning. Put up the 3M, cleaned as much of the dirt off the old tape as I could and put them back up. That was 2 years ago, and still holding on!
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 09-21-2015, 01:49 PM   #1958
Would really like to wire in to my porch light. But the light is in the middle of the awning, not towards either end. So how do I wire up lights up the length of the awning but wire in to porch line, and have the wiring look clean.
Any suggestions?
kdp3078 is offline   Reply With Quote
Old 09-21-2015, 02:32 PM   #1959
Any suggestions?
What's on the other side of the light on the inside of the camper??
I was lucky and there was a overhead cabinet on the inside.. I poked thru the back of the light , tapped into the light feed and ran a wire inside the cabinet down to the end to the hole I drilled outside for the end of the light string...
Joe
Old 09-21-2015, 02:34 PM   #1960
Joe
Sorry, I should have explained better. Wiring in to the light I don't have a problem, it is getting some type of extension, or splicing in the middle of the strip, so I can go straight down from the LED Strip in to the light housing.
I don't want to have to run the strip all the way down, and then run an extension back 8 feet to go in to the housing if there is a better way.
awning, led pad
