Old 07-10-2012, 06:59 PM   #11
Paul & Sheri
pwb01's Avatar
Originally Posted by 10x View Post
Hello newbie here, anyone have a link for led lights on my inside. I would like to replace them with cooler bulbs. any advice on what works best?
Starlights Inc has a huge variety of LED's and you can contact them with questions. Most dealers such as Camping world sells them too. They're not cheap but they save battey big time if you boondock. Most of my fixtures are replaced now.
reducing battery draw is important to me boondocking
I use a 2 gal acumulator tank which saves power (pump runs steady to fill tank pressure instead of on/off using starting amps each time). With that and LED's last week I stayed 5 nights and 6 days and used 20% of the 4 batteries I use (on my meter) That was 3 lights still lit on the panel. I can stay more than a week, no generator.
I have a 120v lamp between two chairs. I converted it to 12v with a bulb I found on Amazon which fits a standard socket, shines 25w with 6w draw. $22, not cheap but very useful and pratical.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 07-11-2012, 05:09 PM   #12
Where did you get the power from for the awning strip? Is there a hot wire on the power awning? Is yours switched? This just shot to the top of my wish list!!!!!
Hitower is offline   Reply With Quote
Old 07-11-2012, 09:37 PM   #13
nowait's Avatar
I have a manual awning - so for the time being I have the led controller, power adapter, and the ac power cord running down the inside of the lower awning arm. I plug it in to the outside AC outlet on the camper.
2008 Silverado EXtCab 6.0 Vortex Max
2010 Forest River Surveyor SV-294
Equalizer 1000 WD/SC hitch
Prodigy Brake Controller
nowait is offline   Reply With Quote
Old 07-11-2012, 11:45 PM   #14
ironj's Avatar
Mine are wired to the 12v in the front storage hatch...they are 12v leds , but many use the 110 to 12v power supply...I ran my wires behind the power awning arm...it had a plastic wire cover already...then tied it into the storage hatch light....
I think there may be another post with pictures and a write up by someone else in another thread...
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
