Old 04-13-2019, 02:38 PM   #1
My WiFi Camp Pro 2 Install
I purchased a WiFi Camp Pro 2 system to help with WiFi service while camping in our Windjammer 3006WK. The Camp Pro 2 appeared to be a well-rated system, at a good price. My only issue was how to mount the antenna. The antenna is directly connected to their "Tube" which is a WiFi receiver. A standard USB cable runs from the Tube/antenna into the RV and plugs into the WiFi router. I didn't want to permanently attach the Tube/antenna to the top of our Windjammer, and I didn't want to put a hole in the roof to run in the USB cable.
I decided to attach the Tube/antenna to a 5' length of 1" PVC pipe and use a vacuum mount from TechnoRV to stick the pipe with antenna to the side of the trailer. I installed a USB port into the outdoor shower box and connected it to the WiFi router which I installed in the water pump cabinet below our pantry. I used a 10' USB extension cable instead of the 25' one that came with the Camp Pro 2 kit. To set up, I stick the PCV pipe with antenna onto the side above my outdoor shower, and plug the USB cable into the port inside the shower housing. I put a small grove in the bottom of the shower housing door for the cable. I'm happy with the way it turned out.
ID:	201594   Click image for larger version
ID:	201595   Click image for larger version
ID:	201596   Click image for larger version
ID:	201597   Click image for larger version
2017 Rockwood Windjammer 3006WK
dankirk is offline   Reply With Quote
Old 04-13-2019, 02:45 PM   #2
Sorry all the pics are rotated, don't know how to fix it.
Here's a few more:
ID:	201599   Click image for larger version
ID:	201600   Click image for larger version
ID:	201601   Click image for larger version
ID:	201602   Click image for larger version
Old 04-13-2019, 03:02 PM   #3
Usually Confused Member
emm-dee's Avatar
Nice job. My CampPro antennae slides directly over a PVC pipe and the cable runs inside. Not sure if it has changed...mine is almost three years old.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 04-13-2019, 08:30 PM   #4
What is the use case for using this unit? It extends the campís WiFi? To increase the signal strength?
borismkogan is online now   Reply With Quote
Old 04-13-2019, 08:50 PM   #5
I mounted my antenna to a 12í painters pole.
Attached to my ladder up 8í. So the antenna is up about 18-20í
I tried one of those double vacuum things. It slipped on my side. I use a bungee cord to attach the painters pole to the ladder.
Works well. Often able to stream movies. Always music/Spotify works.
tomkatb is offline   Reply With Quote
Old 04-13-2019, 08:57 PM   #6
emm-dee's Avatar
Yes. It will see and use many more networks than your phone/tablet. But, you have to have the password for a network to connect.
It can be used to connect to a Mobley if you have one. The Mobley has a five device limit but it doesnít know the CampPro may have 10-15 devices connected.
I rarely use mine since I now have unlimited AT&T and Verizon hotspot boxes.
Old 04-13-2019, 10:10 PM   #7
RandK-M's Avatar
Nice job! I got lucky with mine and was able to attach the Tube antenna to the top of my ladder and run the cable down the refrigerator vent on the roof which was a foot away from the ladder. I put the router on the wall near the floor by the fridge which is above my converter and ran a 12v line from my fuse box so I wouldn't have to use the AC adapter. Makes a nice permanent mount with no cables visible anywhere inside or out.
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
RandK-M is offline   Reply With Quote
Old 04-14-2019, 12:19 PM   #8
"Curmudgeon"
I used the same strategy, but I'm a "big dog", so I mounted 1/2 of a PVC Tee to the ladder with epoxy and extended the antenna out about a foot and then up, but no higher than my "air draft".
Trawlerphil is offline   Reply With Quote
Old 04-14-2019, 02:16 PM   #9
this isn't to hijack this thread, but to offer another method of holding any antenna pole to the ladder, ... I use a 24' painters pole from Lowes for my aftermarket tv antenna and mount it in spring clips attached to the ladder, ... snaps in, snaps out, ... solid, quick, easy, ... I have actually added these clips on both sides of the ladder, the other side is used for a 12' pole for a cell phone signal antenna(which doesn't work very well, but the pole could not mount any easier than snapping it into these clips)
ID:	201700   Click image for larger version
ID:	201701   Click image for larger version
ID:	201702   Click image for larger version
ID:	201703   Click image for larger version
fella10 is offline   Reply With Quote
Old 04-15-2019, 06:40 AM   #10
SternHappens's Avatar
What clamps are you using to mount the spring clips?
SternHappens is offline   Reply With Quote
