Old 09-25-2010, 12:03 PM   #1
Bushman512003's Avatar
Need a little help
I am new here..I have a F.River C.Creek 2005 33' 2 slide I want to fix 2 things the cable for the galley is real hard to open and close all closed in any ideas about where the cable is going so I can get at the end with out removeing the enclosed bottom I would like to make a small door and then patch the hole makes less work I think any others had the fun of this job on the unit I have the cable is to the right of main drain the 4" er the Hose goes to.#2 I have a Honey Well RTH111/RTH221 dig.stat. the 5er has 6 wires used the stat.to go in has 5 spots for the wires now what?any ideas??????????thanks in advance
Bushman512003 is offline   Reply With Quote
Old 09-25-2010, 05:56 PM   #2
milzat's Avatar
Can't tell you where to cut to get to your waste valve. You may be better off removing the under-belly material. It's made in section, so you may only have to remove the first panel.
I removed the whole under-belly on mine just to check thing out. I found one of the heater ducts had come loose from the plenum. It's not hard at all. I used a battery operated drill with a square socket. It doesn't take long to remove it.
milzat is offline   Reply With Quote
Old 09-25-2010, 09:06 PM   #3
Need a little help
Thanks Mike that may be the way I will have to go..John
