Old 04-13-2015, 07:48 PM   #1
Canadian Member
itat's Avatar
Need Pics of Outside Mount for Water Filter
I know lots of members have moved their water filter outside for various reasons. I'm considering doing the same due to the contortions required to replace the filter in the factory location.
If you have mounted yours outside, can you please post pics of your setup.
My city water inlet is on the rear corner behind the ladder, so I'm thinking about a mount to hang on or under the bumper.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 04-13-2015, 09:31 PM   #2
You could also eliminate or bypass your current filter setup and use an inline filter at the city water connection. It's what I did.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 04-13-2015, 09:45 PM   #3
Canadian Member
itat's Avatar
That's an option but the blue Camco inline filter doesn't offer the same filtration level as the OEM. I just ordered a couple F1Pb filters from RV Water Filter Store: Standard Filter Canisters for Whole RV that I want to use in the OEM filter housing.
The stock filter housing is in the bottom of an outside corner cabinet, behind the toilet, so it's pretty difficult to change the filter. I'd like to relocate the housing outside.
Name:	Water Filter Location.jpg
Old 04-13-2015, 10:21 PM   #4
Ret E-9 Anchor-clanker
donanddona's Avatar
X2 on the blue torpedo in-line filter for city water connection. If not I flush the freshwater tank every two weeks...
donanddona is offline   Reply With Quote
Old 04-14-2015, 12:23 PM   #5
bob213's Avatar
I don't have a picture, but I measured and drilled two holes in my bumper. Put long bolts thru with double nuts and then used a wing nut to secure my filter plate. Just remove wing nuts to mount or remove plate. Screw in filter canister, hook up water line from post with quick connect(which has my regulator inline) and you are ready to go. I have a short permanently attached line from the filter "out" that goes to the city water "in".
If someone really needs a picture, I'll go take one later, just ask.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
Old 04-14-2015, 04:06 PM   #6
Check out my post in the Flagstaff section dated 10/16/2014= Relocating water filter: My solution
I hope the info helps you.
Henboy is offline   Reply With Quote
mount, water, water filter
