Old 03-25-2013, 02:38 PM   #11
Originally Posted by RVChick View Post
Cause you are!!
RVChick, yall need to empty your PM file.
Old 03-25-2013, 02:48 PM   #12
CLASS "A" Senior Member
cfsoistman's Avatar
Bought a set of Glacier Bay Bathroom Faucets at HD for under $35 for our powder room at home. I will be using this type when I need to replace mine in the motorhome. As for the three holes that only is necessary if you use the individual valve and spout. As for the drain mecahism they include a small plug that goes in the hole when you don;t require the drain lift pin.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 03-25-2013, 02:50 PM   #13
daydreaming about camping
jeeplj8's Avatar
roger that - well, if the snow will melt enough I can get the trailer out of storage in time this week to do some work on it, maybe have it in place before we go camping this weekend. If the snow melts...
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 03-25-2013, 02:56 PM   #14
Phat Phrog
RVChick's Avatar
Ok
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 03-27-2013, 11:13 AM   #15
jeeplj8's Avatar
Got it installed last night. Did not leak check yet as I did not want to try and run a hose in sub freezing temps.
The sink is actually three hole, they just cut the two they needed.
The drain is not the right size to try and add the pop up drain, not that I think there was room underneath anyway.
Looks good, need to clean up the square left by the old faucet.
ID:	26520   Click image for larger version
ID:	26521   Click image for larger version
ID:	26522   Click image for larger version
Old 03-27-2013, 11:17 AM   #16
I agree, it looks great. Looks like the one I installed. Did you put a rope caulk under the base to keep water from seeping in and down on the things inside the cabinet?
Old 03-27-2013, 11:21 AM   #17
jeeplj8's Avatar
There is a rubber base with the faucet that will stop water from going under the faucet. I am hoping that is sufficient.
Old 03-28-2013, 09:20 AM   #18
jeeplj8's Avatar
so while I was at it, I never liked the bar style faucet they put on the outside kitchen sink. This was not a problem of appearance, it was actually very nice looking, but rather performance. It only stuck out about 1 inch. I think it was designed to be mounted inside a sink, not on the counter-top behind the sink. It was not possible to wash ones hands without getting water all over the counter. This bothered me to no end.
So I went up to Home Depot and found a laundry sink faucet that had a pull out sprayer. Less than 40 bucks. It is chrome which I don't like, but I could not find a stainless or nickel version anywhere. It makes the sink much more usable. And has a hose thread end on it so I now have an outside hose spigot on that side of the trailer.
ID:	26589   Click image for larger version
ID:	26590   Click image for larger version
ID:	26591   Click image for larger version
ID:	26592   Click image for larger version
Old 03-28-2013, 09:50 AM   #19
caper's Avatar
You should have put some plumbers putty under it as well The rubber base will work but the extra insurance does not cost must and could save the counter top. Most times the instructions recommend using putty.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-28-2013, 09:56 AM   #20
And it is so easy to do. This stuff can be used just about anywhere and it never hardens. Frost King E/O 1/4 in. x 90 ft. Rope Caulk Woodtone-B2WT at The Home Depot
I carry a roll in the camper.
