Old 06-13-2016, 04:54 PM   #11
Need To Raise 5th Wheel
Kenny Kustom, can you please explain in detail how you lowered your 2015 ram 3500 (I have the same truck and would also be interested in the same modification. 2012 8244ws Diamond Package 5th).
archgard is offline   Reply With Quote
Old 06-13-2016, 05:48 PM   #12
How to Lower Truck
X2
ksmith954 is offline   Reply With Quote
Old 06-13-2016, 06:20 PM   #13
Kenny kustom's Avatar
Ram 3500 lowering
Easy!!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 06-13-2016, 06:27 PM   #14
BandJCarm's Avatar
Ask a 20 year old. Clearly they all know how to do it! LOL
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 06-13-2016, 06:36 PM   #15
Need to raise 5th wheel
Kenny Kustom
Perfect, picture says a thousand words
That's the way to do it.
Old 06-13-2016, 06:57 PM   #16
trbomax's Avatar
Originally Posted by GreenImp View Post
20 years ago I never would have dreamed I'd ever say this, but these days I would much rather lower my truck than raise my trailer.
...I am of at least average height, and I already struggle to reach things in the bed sometimes
...most modern trucks (4x4's anyway) have WAY too much space in the wheel wells already (my opinion)
...lifting the trailer will raise it's center of gravity (bad)
...lowering the truck will lower it's center of gravity (good)
...lifting the trailer will increase the distance to the first step when entering
...lifting the trailer will increase the distance needed for all leveling jacks/landing gear every time you set up
just sharing my thoughts is all
Agree with this.I lowered my f250 2" in front and 4" in rear.
trbomax is offline   Reply With Quote
Old 06-14-2016, 10:50 AM   #17
I read in one of the towing or hitch guides not to run nose high, however, you may want to weigh your rig before you decide. In my situation, my 8289WS has more weight on the front axle which suggests it may be running nose low. I plan to hook up and take some measurements this weekend and could end up raising the nose on my unit to transfer weight to the rear axle.
If your 8289WS is setup the same with the refer and oven on the left side slide, it appears the left is the heavier side.
My left front wheel is the heaviest, the left side heavier than the right, and the front axle is more than the rear. Considerably so...
Attached is my weight sheet.
2015 Rockwood 8289WS
2003 Dodge Cummins w/Banks 3:73
CraigBean7672 is offline   Reply With Quote
Old 06-14-2016, 04:34 PM   #18
Why use lifts???? Why not raise/lower hitch in truck???
Jim in Halifax is offline   Reply With Quote
Old 06-14-2016, 05:55 PM   #19
GreenImp's Avatar
Send a message via MSN to GreenImp
With a 5th wheel, the front of the trailer overhangs the truck bed. Because of this you can only lower the hitch so far before running into clearance issues between the trucks bed side rails and the trailer. The recommended minimum clearance is generally 6" (my current setup has 5" of clearance when on level ground).
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 07-17-2016, 11:34 AM   #20
PhoneDude 8289's Avatar
I did get the 5th wheel raised 3" and it was perfect for the Ram 2500. Here are pictures I said I would post. Before raising the RV it was almost 5" nose high. Took me about 6 hours to install the lift kit, I was alone. Towed level with my previous truck an 08 Tundra.
Lifted 2014 8289WS Diamond pkg
2014 Ram 2500 4wd SB DC TCD
PhoneDude 8289 is online now   Reply With Quote
5th wheel, wheel
